Best Readily-Available (ie. non-mail-order) Cetane Boost/Additive? - Ford Powerstroke Diesel Forum
Old 01-07-2010, 02:52 PM
I know "best" is controversial adjective, but is there a consensus on a readily-available fuel additive that can be used regularly? Sort of like Techron for gasoline engines? Yea, I'm a noob to these compression-ignition things... LOL! TIA!
Old 01-07-2010, 03:36 PM
Send a message via AIM to jhaddox
a good bottle of the white powerservice...they sell it everywhere....
Old 01-07-2010, 03:43 PM
I'll look for it at Wally World tonight...
Old 01-07-2010, 06:17 PM
Just look up stanadyne or fppf distributors in your zip...there is usually someone that has it. Your dealer has Motorcrafts cetane booster
Old 01-07-2010, 06:29 PM
Send a message via Yahoo to cxrxaxz
Just my opinion but i didnt like the powerservice crap at all. I normally use STP diesel in the blue bottle and have for some time ever fill up. I decided to use some of that powerservice stuff one day because i was in orileys and seen it. Well when i put it in i got pretty good mpg out of it but had horrible cold starts. The truck would shake for like 15-20 minutes and it would even shake a little after it had warmed up. I thought i had an injector going out. well after that take was empty i went back to my blue stuff because i can get it at the store beside my house and all my problems went away. I can go out in 15 degree weather and start my truck right up with no shaking or acting stupid lol. I have no idea why it did this to my truck. i added the right amount. (threw the rest away after i figured out that was the problem.)
Old 01-08-2010, 02:30 PM
Send a message via Yahoo to Lubbockguy1979
I use wally world supertech tcw3 two stroke oil. It has made a my truck a lot quieter at idle (less clacking) and it starts better. It has been tested and is one of the best lubricants to use as a additive. I use 1oz to every gallon of fuel or 32oz per tank.
Old 01-08-2010, 02:51 PM
I know 2-stroke oil was "good snake oil" for older PSD's, but do they have the cetane boost that even Ford recommends? That's really what I'm after....
Old 01-08-2010, 02:56 PM
the only thing that ford will recomend is their own motorcraft stuff
Old 01-08-2010, 03:08 PM
The Power Service stuff has the cetane boost in it, right?
Old 01-08-2010, 03:53 PM
I'm not having any issues not using cetane. And from what I have learned it is not an issue. The issue with all huei psd engines is injector lubrication. That is why we use a additive. And two stroke oil is not snake oil. It is dino oil. And it preforms about 3x better than diesel kleen in lubrication.
