New Insight not working???
I got a new edge insight and It worked for about a day and now it won't power up.... the computer won't recoginze that it is connected either.... it won't even light up in the truck and will light up with red when i plug it into the computer but thats it... it says there is no new updates availble... any thoughts?
check the plugs?
you might have to call tech support, Im stumped
Have you checked the fuse?
Hit it on something
ill check the fuse tomorrow.... i was planning on calling in the morning cause i tried tonight and was too late in the evening.... but this is what i don't get.... my brother actually bought it... and he is not a truck person.. just wants things to work and doesn't care as long as they work type of guy (not like us)... i told him that i really wanted one and he said well if you want the dang thing you install your gauges in my truck and do all the work and you can have it... i said deal... but i am the one who installed it in his truck with the probe and everything worked great when i first installed it... he was headed somewhere and said it just stopped working (30-40 minutes later i suppose)... so that is why he made the gauge deal cause he didn't want to deal with call edge and all that... so i installed my gauges in his truck today and the insight didn't work in my truck at all... so ill call tech support tomorrow... maybe its just a bad unit
i went out and plugged up my SCT to see if the OBDII was working and the SCT fired right up so its not a blown fuse... something is wrong with the insight i think..
hey fellas.. i called edge first thing thing morning cause i was positive i had done everything right and covered my bases by that point.... turns out that the egt probe was what was causing the communication loss..... as soon as i unplug/plug in the edge probe to the connection part of the insight cord it turns on/goes off.... so they are sending me a different probe cord... everything is great.. thanks for the suggestions and help....
on another note... the guy at edge says he has seen plenty of problems with then insight and sct being used together... he said they see a lot of cases where the insight won't read "all" the parameters it's capable of when being used with and sct... you guys having any problems with yours? Another question.. I can't get my insight to connect to my computer... i would like to be able to get everything set up while there is snow on the ground and have it read for the truck when i get done... but it always says "disconnected" in the status bar at the bottom of the insight software screen... any thoughts? Last edited by strokepower; 01-06-2010 at 03:07 PM. |
