are my head gaskets blown? - Ford Powerstroke Diesel Forum
Old 01-04-2010, 08:14 AM
I was looking for an oil leak and when the truck was running looking through the passenger side wheel well I could see liquid bubbling out of the exhaust manifold on the port closest to the front of the truck. Does that mean my gaskets are blown? Also have an egr delete btw so its not the cooler
Old 01-06-2010, 04:22 PM
bump.......
Old 01-22-2010, 12:19 PM
bump.. this is wierd i thought u dont get water in the exhaust from a head gasket, only egr?
Old 01-22-2010, 02:22 PM
You sure it's water and not fuel? A bad glow plug or a abad injector could be failing to ignite the fuel there... Just a guess? Seems like water would boil off immediately...
Old 01-22-2010, 08:25 PM
Feedback Score: -1 reviews
you using coolant? doubt its coolant maybe take a picture or sample and post it up
Old 02-11-2010, 12:48 PM
injector harness
just was messing around with the connectors and looks like when i did my egr delete somehow i bumped the fuel injector harness where it plugs into the cylinder that this is happening on it is cracked and not making a good connection, this must be it right?
