antifreeze - Ford Powerstroke Diesel Forum
Old 01-04-2010, 04:57 AM
antifreeze
this mornin and yesturday mornin whn i went to get in my truck i noticed a small amount of antifreeze under truck about this size of your palm. looks like it is dripping very little out of the bottom hose. is this normal? its about 20 degrees here in alabama
Old 01-04-2010, 09:02 AM
sometimes cold water leaks develop pretty normal thing to happen in cold temps... i would drain the coolant, pull the hose off clean it up good maybe take a wire buffer to it gently reinsall it, maybe dope it up with some high tack gasket sealer and reinstall it and give it a shot. if that dont work its time for a new hose. hope this helps
Old 01-04-2010, 11:43 AM
ok i'll try that. thanks for the help
Old 01-04-2010, 06:39 PM
Small amount of anti-freeze where? What location under your truck?
