Going to cold weather. What to prepare for? - Ford Powerstroke Diesel Forum
post #1 of 30 Old 01-03-2010, 07:40 AM Thread Starter
Hey everyone. As i have seen from a lot of posters, there seems to be a good amount of people that have these trucks in cold weather. I'm looking for some info on what to expect as I am from CA and will being going to Brian Head , Utah(right now temps are 30F-10F) in the end of Jan for a snowboarding trip.
Are there anythings in particular that i need to do? oil? coolant? anti-fuel gelling? buying an engine block heater?
Thanks in advance!
2004 F250 CC SB 6.0
SCT X3 Custom Tuned: Eric@IDP, Matt@GearHead
Edge Insight Monitor w/EGT Probe
Zoodad Mod
High Idle Mod
Tough Country 2.5" Front Leveling Kit
MBRP Turbo back exhaust and a dead cat
ARP Studs
New Oil Cooler and EGR cooler
Dieselsite Coolant Filter Kit
305/75/16 Nitto Dune Grappler
fordstang93 is offline
post #2 of 30 Old 01-03-2010, 07:44 AM
shaking things up
jethro's Avatar
how long will you be there? if not very long i wouldnt worry about alot just keep a bottle of PS911 in the truck just incase you have problems also fill up with fuel from that area as soon as you can as it should have anti gel in it and your cali fuel most likely wont
389.14 HP 726.00 TQ
96 f-350 7.3 with a 5 speed
3 in DP
4 in ex. to 5 in aussies
custom traction bars
TW chip 6 pos
IDM mod
SD IC
HPX
D66
casserly 2's
custom fuel with an AIRDOG 2
910's
*17 TE modded hpop
ebpv gutted
pedestal gutted
gutted ccv elbow
clutch pedal fix
facebook- Graham Maxwell
jethro is offline
post #3 of 30 Old 01-03-2010, 07:50 AM
Sins4u33's Avatar
Send a message via AIM to Sins4u33
he pretty much nailed the head, just let the glow plugs warm up fully when u start it, it def wont like being started in the cold, i usually plug my truck in down here in VA, its been in the 20's recently at night with a wind chill of like 10degrees. but my truck came equipped with a block heater. Def makes start ups much easier on the truck.
Ben Y
F250 Supercab FX4 Lariat
SCT Xcal3 w/ Innovative Diesel Custom Tunes
MBRP 5" Turbo Back Exhaust, ARP Head Studs,
AFE Stage 2 Intake w/ Pro-Guard, EGR Delete
RECON Lighting, Zoodad Mod
18" KMC Rockstar XD's w/ Nitto Terra Grapplers 325/60's
Future mods:
-6inch Lift
Sins4u33 is offline
post #4 of 30 Old 01-03-2010, 07:51 AM Thread Starter
Nice
That's what i was thinking...as long as i fill up around there the fuel should be ok. Good call on the PS911. Any recommendations on where to get it? The PS911
I'll be there for 5 days 4 nights.
2004 F250 CC SB 6.0
Zoodad Mod
High Idle Mod
ARP Studs
post #5 of 30 Old 01-03-2010, 07:54 AM
StarDriver's Avatar
Any truckstop will have it, look for the one's near where you are going, I'd dump some of the 911 in or use some HOWE'S Diesel Treat, you can use more than what they recommend and it won't hurt anything.
2006 F-350 4X4 FX4 Tuscany Longhorn , Leer Custom bed cap, RECON lights, Upfitter switches, Whelen Lighting, Hi-Idle Mod.
Instructor at B.R.A.K.E.S (
28 years Commercial Driver.
StarDriver is offline
post #6 of 30 Old 01-03-2010, 07:55 AM Thread Starter
day time temps
being going to Brian Head , Utah(right now temps are 30F - 10F) in the end of Jan
Those temps are day time temps.
2004 F250 CC SB 6.0
Zoodad Mod
High Idle Mod
ARP Studs
post #7 of 30 Old 01-03-2010, 07:55 AM
mrnecsteve's Avatar
Take long underwear with you.....
OHHH..you mean for your truck?
Change your oil to some synthetic. Buy two hydrometers,(cheap) one for your radiator fluid and one for your batteries and check all three. Recheck the condition of youre serpentine belt.. The cold brings out the worst in these items.
mrnecsteve is offline
post #8 of 30 Old 01-03-2010, 07:59 AM
BLACK_PSTROKE's Avatar
id add the white bottle of power service to your fuel on fill ups. i would take every step possible to avoid putting 911 in my tank. just my$.02
09 F250 FX4
2n006 F-350 fx4 lariat
cc. 6 sp. man. SOLD..........
MEMBER $5.00 gallon club
NRA member
BLACK_PSTROKE is offline
post #9 of 30 Old 01-03-2010, 08:00 AM
shaking things up
jethro's Avatar
5 days and 4 nights is not worth buying or installing anything special except the ps911 you can probably pick it up just about any parts store around there. and do let the gp's cycle atleast once before start up. if it is really cold ie less than 20 degrees i would cycle them twice and allow the truck about 5-10 min of warm up time b4 heading out on the road
389.14 HP 726.00 TQ
3 in DP
TW chip 6 pos
IDM mod
SD IC
HPX
D66
casserly 2's
910's
*17 TE modded hpop
ebpv gutted
pedestal gutted
gutted ccv elbow
clutch pedal fix
jethro is offline
post #10 of 30 Old 01-03-2010, 08:23 AM Thread Starter
awesome
Again...thanks everyone for the feed back.
2004 F250 CC SB 6.0
Zoodad Mod
High Idle Mod
ARP Studs
