keyless entry buttons - Ford Powerstroke Diesel Forum
Old 01-02-2010, 07:38 PM
hey guys i have an 04 f-350 and it has the bottons on the outside of the truck and i was woundering if there is a spot on the truck that i can find the code i know some cars have it in the trunk and do i have to take it to ford to reset the code or is it something i can do? thanks
Old 01-02-2010, 07:58 PM
Cunning Linguist
Ford will be able to pull the code out of your computer with a scanner.
Old 01-02-2010, 08:20 PM
Location: surfing, spearfishing, using my powerstroke to tow boats to the river!
My manual has a credit card size plastic thing in it that has the code and instructions on it. If its not in your book you can take it to the dealer and the will plug into your computer on your truck and find it for you. The dealer wanted to charge me 50 bucks to do it though. Thankfully I found my card. You might be able to talk them down though
Old 01-02-2010, 09:05 PM
or you can look under your dash and up by the radio there is a sticker with the 5 digit number. You might have to move some insulation around but it is up there. It really wasnt that bad to get to!
Old 01-02-2010, 09:14 PM
i have the card in my book but not keypad on the outside. does anyone know where i can get the keypad and how hard are they to install?
Old 01-03-2010, 04:13 AM
That's how I got my code too
Old 01-03-2010, 05:19 AM
Send a message via MSN to james7977
what i did was reached up behind the radio and there is a box with a sticker on it i just peeled the sticker off and taped it in the owners manual but that has the code on it my truck is also a 04
Old 01-03-2010, 05:54 AM
i found my code wrote in the door jam with black permanent marker up front between the door hinges. i just happened to see it while detailing my trk saved my a trip to the dealer.
Old 01-03-2010, 06:44 AM
My sister has an 06 Freestyle, came with remote key pad, but no number pad on the door. She bought a kit from the dealer, came with a new key pad remote, and a stick on number pad for the door.
Old 01-03-2010, 06:53 AM
Did you have to pull the radio out to see that sticker??
