swap 6.0 for 7.3 - Ford Powerstroke Diesel Forum
Old 01-01-2010, 07:13 AM
Question swap 6.0 for 7.3
Hello and thank you for having this forum.
I have an 03 6.0 that has started to have problems. Injectors going out and loosing compression in one cylinder, 30% low. Mechanic is giving me some outrageous prices and suggesting that I just get a new motor. This one only has 100k on it and I have taken care of it since I got it, but the last owner put most of the miles on it so who knows what he did to it.
So for my 2 questions.
1) What can I do, myself to repair my current problems? Any suggestions for where to start a diy repair on this motor. How can I possibly diagnose if this is a head problem or if its something else.
2) due to all the problems that I am learning that the 03 6.0lt has I'm considering finding a 7.3 used and swapping them out and parting out my extra parts. I have a 4x4 6.0 If I find a donor truck with a 7.3 what parts will I be able to keep using in my truck, ie will I have to swap transmissions/transfer case or will my tranny work? Will I need all new everything or will I only need the 7.3 and a new wiring harness?
Would love any other thoughts about this task that i'm about to overtake one way or the other.
Old 01-01-2010, 07:47 AM
do a 12v swap
Old 01-01-2010, 08:07 AM
At a minimum (and I am sure there is much more) You would need a complete doner truck with all of the wiring harnesses, the IDM, the PCM a trans unless its a manual then it might be the same (I dont know).Fuel system tweaks, plus mounts and basic plumbing.
I would personally do a 12V swap also.
Old 01-01-2010, 08:17 AM
Take it to an INTERNATIONAL dealership, have them do the bare minimum to get it back in OK running condition, and SELL it. Then go put the money down on a leftover '09...they'll be making some crazy good deals on them in the next 2 months.
Old 01-01-2010, 08:44 AM
what kinda deals on 09's?
Old 01-01-2010, 08:49 AM
A 7.3 swap wouldnt be that hard in your truck , in 2003 they cam in 7.3 or 6.0 , the mounts are the same transmissions should match in the 6 speed the automatics wont match up , you should find a 7.3 truck get what you need and sell the rest . it shouldnt be that bad .
Old 01-01-2010, 10:10 AM
My buddies 04 6.0 just turned 320,000 miles. The only thing he's ever replaced was his FICM and had the rear end re-built. I'd fix yours and keep it.
Old 01-01-2010, 10:23 AM
Pointless Poster
12v swap.....
Old 01-01-2010, 10:25 AM
I have not tried to see, but with the "New" diesel comming, it only makes sense to think a screaming good deal is out there..
Here's a 2010 I just found, seems like a good deal?
OHIO
Old 01-01-2010, 10:39 AM
well any diesels you find now will have been built before jan 1 . the diesel line has been shut down to retool for 6.7 . first ones are coming to our dealership some time in feb .
i know we really arnt discounting them any more than what fords handing out.
