oasis and questions - Ford Powerstroke Diesel Forum
Old 12-31-2009, 10:56 AM
oasis and questions
first i was wondering if i could get an oasis vin#1ftsw21p36ea24366
second once you go to synthetic motor oil could you go back to regular oil if needed, not saying i will just if i ever had to
Old 12-31-2009, 11:08 AM
Yes you can switch between synthetic and regular oils. You can also mix the two if you have too, just ensure they are the same weight oils.
Old 12-31-2009, 02:31 PM
thanks for the info, hopefully i will never have to give up the synthetic
Old 12-31-2009, 02:36 PM
I have heard people say they don't recommend switching, though I can't see why it would make a difference.
Old 01-02-2010, 07:47 AM
When the syn stuff first came out and was cheap enough for all of us to buy it was a problem with blending them. Now it is not a problem at all and you will have no trouble going between the two if you have too
