Oil temp sender - Ford Powerstroke Diesel Forum
Old 12-29-2009, 07:19 PM
Exclamation Oil temp sender
I just picked up some new gauges and im not sure where to install an oil temp sender. the only place that i see is in the stock location by the oil filter. Is there a better place?
Old 12-30-2009, 06:32 PM
evening bump
Old 01-05-2010, 06:44 PM
does anyone else run one of these gauges??????
Old 01-05-2010, 06:54 PM
Chug-a-lug!!!
Read the second post. Maybe it will help you. I'm not sure. Here's a free anyway.
So where does Fords computer get oil temp
Old 01-05-2010, 06:55 PM
I'd probably drill and tap the HPOP cover, this oil would be post cooler so would be a great place to take a reading, someone might have a better location though.
Old 01-05-2010, 07:51 PM
There are metal oil filter caps available with a threaded plug, maybe the sensor would work there.
On other vehicles I have used the oil drain plug.
