Coolant Filter Installed
Ok... so I paid out the 3G last month to fix my EGR cooler/oil cooler problem, and installed a coolant filter yesterday. Is this a sure fix? Has anyone experienced an EGR failure with this filter kit on? Just looking for assurance that this is a solid solution.
Thanks, nate Last edited by FordOD; 12-29-2009 at 06:55 PM. |
wow 3 grand why didnt you just do a egr complete delete that is a sure fix cost alot less moola too
CA
Because some people live in CA and unfortunately in 2 days they will officially begin emissions testing diesel in CA. So until someone figures out if an EGR delete or block off will cause a failure based on emissions testing(not visual inspection as they can not really see it), it's not worth the time or money to do a delete or block off.
just my $0.02 |
I know it's off topis, but:
Just food for thought here, but what if someone from another state came into CA just to get a smog test WITH the delete kit on. Kind of a "feeler" to see what it would blow. Maybe this would give everyone else some sort of baseline as to what you could get away with. Will they test you if your a non resident? And can they do anything about it if you do fail seeing as how your from another state? Congrat's on your filter install. I would definitly think it would help. Last edited by kimber_da; 12-29-2009 at 08:19 PM. |
nice
good to know. I started a thread a little bit ago trying to get info on EGR delete/block off with emissions testing....didn't really get anywhere.
Do you know what tests were performed besides the opacity test.? Last edited by fordstang93; 12-29-2009 at 08:18 PM. |
1) Visual - checking for all emissions related equipment equipped from the factory, which they include the turbo, EGR valve, EGR cooler, CAC, Cat, DPF, aftermarket tuners, Mass Air Flow Sensor, etc. Any missing or modified equipment will equal a failure. 2) OBD II - They will plug into the vehicles OBD port and check for any active DTCs that are emissions related. Any emissions related DTCs will equal a failure. 3) Snap Test - snap throttle from idle to between 2K and 3K rpm 3 times. On 2nd and 3rd time no visible smoke must linger after 3 seconds. If smoke lingers for more than 3 seconds on tries 2 OR 3, the vehicle fails. More information avaliable here: Diesel Vehicle Smog Check Inspections Information |
what kit did you go with?
What a stupid state.
I'm not sure how the inspection process works in California, but in MA there are 2 types of inspection stations (Commercial, and non-Commercial), some stations can inspect both. I would try to find a gas station that inspects both, as they're not 100% familiar with diesels... but an EGR delete will be verrryy hard to pick up on these trucks. |
