6.0 Temp? - Ford Powerstroke Diesel Forum
Old 03-28-2007, 06:14 PM
6.0 Temp?
Hey guys quick question.
How long does it take for your 6.0 to reach normal operating temp?
Mine takes a good 15-20 miles before it gets anywhere near where it should be according to the guage and that is in 50-60 degree outside temp. If I let it just sit there for 10-15 min and idle the trans warms up to temp quick but the engine guage never moves.
Let me know what you think.
Old 03-28-2007, 06:48 PM
my truck doesn't take THAT long. If I drive my truck everyday it warms up faster then if it sits for a couple days. on average it takes about 10 mins for it to reach normal operating temp. there might be an issue with the trucks engine sensors telling your dash how hot it is. but I would assume that would set a CEL. good luck man.
Old 03-29-2007, 04:35 AM
I'd guess around 10 minutes or so. But I live in South Texas.
It's funny: a lot of the guys on the site say they let theirs idle for 10-15 minutes in cold weather and that gets the motor warm. But the owner's manual on my 07 says that idling won't adequately warm the motor
So mostly I just drive mine gently until the temp climbs into the operating range.
Old 03-29-2007, 04:49 AM
The Fat Mod
Thats the best thing to do Manatee, mine prolly takes 5-10 min. depending on the outside temp. Do you have any extra guages, or just the factory ones?
Old 03-29-2007, 01:03 PM
thanks for the help guys.
I think i'm gonna take it to the dealership, there has to either be a problem with the thermostat or the guage. There is no reason that i should have to ride for 15-20 miles after i let it idle for ten minutes before the guage ever reaches its normal range.
Actually I think it has to be either the sending unit or the guage because i've got good heat long before the needle ever moves off cold.
Old 03-29-2007, 01:19 PM
SMOKE ROLLER
Old 03-30-2007, 05:16 AM
Just the factory ones.
BTW, diesel jumped to 2.79/gal here overnight
Old 03-30-2007, 05:20 AM
That factory gauge is a glorified idiot light. Not very accurate.
Old 03-30-2007, 01:56 PM
If you open a store in Corpus Christi I'll pay you to put good gauges in mine I drool over all the great mods folks are making but I'm all thumbs. The cat delete pipe was the absolute limit of my skills
Old 03-30-2007, 02:54 PM
LTJDS
Gauges not hard
Most gauges are not hard. Unless you add tapping your exhaust manifold for an EGT probe. But you can easily mount the probe post turbo with little trouble. I installed my fuel pressure , boost , pyro, and tranny gauges. The extreme hardest was my EGT, but I tapped my exh manifold , my prior truck only had a post turbo EGT gauge. All the others are fairly easy.
