Pipe Covering - Ford Powerstroke Diesel Forum
post #1 of 17 Old 12-26-2009, 01:33 PM Thread Starter
SickStroke6.0's Avatar
Feedback Score: 9 reviews
Pipe Covering
Hey guys! I'm not real sure what pipe this is, but I've seen a few of you guys engines without the black thermal wrap around this pipe. Would it be okay to remove? And would it void my warranty, or hurt/help my engine?
Mine has a small tear in it too, and it seems really easy to remove.. so can I?
THANKS GUYS!
Blake
2013 F-150 CCSB Oxford White FX4 EcoBoost
Loaded with every option...
2008 F-250 CCSB Dark Copper King Ranch 6.4L FX4
4" MBRP Exhaust w/ Muffler (DPF/DOC Delete), Modded Stock Intake, H&S XRT Pro
SickStroke6.0 is offline
post #2 of 17 Old 12-26-2009, 01:40 PM
mule-isky's Avatar
na you should be able to remove it fairly easily its pretty much a foil delete
mule-isky is offline
post #3 of 17 Old 12-26-2009, 01:48 PM
MoyockPowerstroke's Avatar
Interesting....what MY do you have. My MY '05 was never like that...it also doesn't have the hood liner. Was this covering used to keep the CAC tubes cooler?
'05 6.0L, 128k miles, Racor CCV6000 Filter, Oil Bypass Filter, Fumoto drain valves, Coolant Filter, ZooDad, HighIdleMod, BullyDog 4" TB, VXCF9 Strat, Edge Insight Gauge, Torque App, Fuel Press Gauge, Upfitters, 4" SJ lift w/Bilstein 5100's, Ride-Rite Airbags, Rough Country Dual Stabilizers, 24" Wipers, '08 Rear Diff cover, Mobil1 Syn 5W-40, 6.4L banjos, Blue Fuel Spring, SS HPOP screen, '08 Mirrors, Zerex ELC.
MoyockPowerstroke is offline
post #4 of 17 Old 12-26-2009, 01:54 PM
smokersteve's Avatar
Quoted: 20 Post(s)
This is your turbo boost tube. The wrap is to prevent the transfer of heat for the intake. But im not sure witch is better, cus the compression of the air creates heat and the eng creates heat. I just depends on whats dominating. If the intake creates allot than take it off but if it doesnt, then keep it on to prevent the heat of the eng.
13Q Trans Fluid Flush
FICM Testing Videos
smokersteve is offline
post #5 of 17 Old 12-26-2009, 02:02 PM Thread Starter
MY? What is that?
Blake
post #6 of 17 Old 12-26-2009, 02:14 PM
model year yet it is in your sig if someone looked.......
03 F350 SRW CC LB 4x4
4" Lift, 33 Tires, Pro Comp Trac Bars.
CFM+ Largemouth KIT
MBRP 4" straight pipe
SCT By DJ
ISSpro Gages
Rack it Racks
Debating Fass or RR
dayusex is offline
post #7 of 17 Old 12-26-2009, 02:14 PM
jhaddox's Avatar
Send a message via AIM to jhaddox
Originally Posted by MacbooknMyTruck View Post
MY? What is that?
MY-Model Year
and his is an 03 it says it in his sig
08 ECSB 6.4
MPD, GOGO, No Limit, Rudys, ARP, PMF, Innovative, AFE, Recon, Fuel, Nitto, Bilstein
jhaddox is offline
post #8 of 17 Old 12-26-2009, 02:17 PM Thread Starter
MY= Model Year
Yeah, it's an '03
Blake
post #9 of 17 Old 12-26-2009, 02:29 PM
Okay...Okay...I realize now that I wasn't signed in...jeez. So I guess this is another missing item from later MY's. Ford was leaning out their overhead...I wish I had the hood liner though.
post #10 of 17 Old 12-26-2009, 02:31 PM Thread Starter
Why???
Blake
