hey how to get oil out - Ford Powerstroke Diesel Forum
Old 12-25-2009, 09:40 AM
hey how do you get the oil out of the valley where the oil cooler sits?
Old 12-25-2009, 10:00 AM
Take it to a detail shop and they can steam wash your eng.
Old 12-25-2009, 10:35 AM
nono, i pulled the oil cooler out, where the oil cooler sits in it has about a 1/2-1 gallon of oil in there. i'm rebuilding the cooler and i want it sitting in new oil when i put the new cooler back in.
Old 12-25-2009, 10:42 AM
O! Suction pump, cup, sponge, turkey baster
Old 12-25-2009, 04:45 PM
I just drained mine out two days ago. I used a dixie cup to scoop, and a 2 quart container to dump it into. Then some rag to mop up the rest. Its a little less than two quarts in there.
Old 12-25-2009, 07:05 PM
cRaaZy8....is there a screen down there that needs to be replaced? If so, do you know the Part Number?
Old 12-25-2009, 07:24 PM
ya there is, i can get you the part number in the A.M if i don't forget
Old 12-25-2009, 08:18 PM
thenubsterman...Thanks buddy. Were you doing an EGR delete and decided to overhaul the oil cooler or were you having issues with the cooler? How hard of a job was it to pull the cooler and overhaul it? Do you think there will be any issues with firing her back up?
Old 12-25-2009, 11:49 PM
Bulletproofdiesel sells a stainless steel screen in case you are interested.
Old 12-26-2009, 08:01 AM
screen part number
the ford number is (3c3z-6c683-ab) filter asy list for $11.60
