idk where the wetness is comin from.
Hey everyone, so doing all 8 injectors, and while i was at it. My MAP sensor port got jamed with crap in it. well i pulled my egr valve out it was all wet inside. So i figured the egr cooler must be leaking well tear the intake off its dry by the intake the oil is causing this wetness which i believe is causing my port to get jammed. The oil i believe is coming from the breather out of the valve cover. anyone else experience this condition. I will be blocking both sides of egr cooler off while i'm ine there. and i'll be rebuilding oil cooler
