305/70/17 Tires on Stock Wheels - Ford Powerstroke Diesel Forum
Old 12-22-2009, 11:19 AM
I am considering putting 305/70/17 Nitto Terra Grapplers on my 2005 stock height 250 with the 17" factory rims. Is anyone running this setup and could you post a pic if possible? Do you think these tires will fit on the truck without rubbing?
Old 12-22-2009, 03:43 PM
x2. I want to upgrade to a larger tire on stock wheels/ride height.
Old 12-25-2009, 11:45 PM
MSharpe505...tell me more about your truck...i have an 04 ext cab...the fx4 version. it comes stock with 285/70/16s...i know that i can fit 315s on there without rubbing...but that's cuz the fx4 has those rancho shocks that keep the truck sitting a little higher than others...i would say you could probably shove those 305s on there without rubbing. you want a definitive answer tho...i'd call a local ford dealership and ask them what the biggest tire you could do based on your truck setup...
Old 12-26-2009, 05:10 AM
Almostdunfukinwidit
Sure they will work just fine. Im running 315/70/17s on my stock wheels
I would look into a leveling kit though
Old 07-17-2011, 09:24 AM
Why do you recommend a leveling kit?
Old 08-13-2011, 01:59 AM
Sharpe did you ever end up getting this setup?
Old 08-13-2011, 04:34 AM
Almostdunfukinwidit
It just looks better. And gives a little more clearance in the front if you off road at all.
Theres enough stock though
