What PIDs to monitor on CTS? - Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By DMc
post #1 of 7 Old 05-19-2017, 09:49 AM Thread Starter
belz's Avatar
Quoted: 76 Post(s)
I have gauges for boost, egt, trans and fuel pressure. What do you guys recommend for the cts? Currently have ect, eot, ficm volts, battery volts, ipr %, icp volts, icp pressure and ficm sync. I feel like i can put to better use the spot for ficm sync.
belz is offline
post #2 of 7 Old 05-19-2017, 09:57 AM
jokester00's Avatar
Quoted: 105 Post(s)
Garage
I know you said CTS, but there was just a thread regarding the CTS2.
CTS 2
I have the CTS2 and I monitor fuel pressure, EGT, battery voltage, FICMv, EOT, ECT, Trans temp, VGT%, & ICP on the home screen. The other screen I have setup with PID's for a no-start or troubleshooting.
-jokester
2005 F350 CCLB FX4 Lariat
ARP's with OEM gaskets
SCT SF3 - Currently running Gearhead 8K Tow Tune
Edge Insight CTS2 monitor
Edge EAS EGT probe
Edge EAS Fuel Pressure Sensor
DieselSite Coolant Filter
Blue Spring Upgrade
jokester00 is online now
post #3 of 7 Old 05-19-2017, 11:34 AM Thread Starter
belz's Avatar
Quoted: 76 Post(s)
Didnt know you could set up a second screen. Or is that a cts 2 thing. Still trying to learn everything. There's a lot more stuff to know compared to the ol 7.3.
belz is offline
post #4 of 7 Old 05-19-2017, 06:10 PM
jokester00's Avatar
Quoted: 105 Post(s)
Garage
I'm not sure if it's a CTS2 only thing or not. I haven't had the chance to play with a CTS yet.
-jokester
post #5 of 7 Old 05-19-2017, 06:50 PM
DMc
Quoted: 209 Post(s)
If you haven't given your CTS the latest update, doing so will give you a screen to monitor 10 pids at once. Then you can spend even more time figuring out what to watch!
jokester00 likes this.
2004 F250 4X4 CC SB
DMc is offline
post #6 of 7 Old 05-20-2017, 04:14 AM Thread Starter
belz's Avatar
Quoted: 76 Post(s)
I did the update. Still only shows 8 at the most. Unless they came out with another update within the past 3 weeks. I downloaded the manual yesterday. Just have to play with it more. So much to learn on this new truck. Just not able to get it all in within the time ive had it. Thanks guys.
belz is offline
post #7 of 7 Old 05-20-2017, 10:00 PM
DMc
Quoted: 209 Post(s)
No, it's an old update. You should have a screen with the pitch and roll indicators on it. That's the one that has room for 10 pids.
2004 F250 4X4 CC SB
DMc is offline
