Trailering my Crew cab Long bed - Ford Powerstroke Diesel Forum
 24Likes
post #1 of 32 Old 05-19-2017, 02:51 AM Thread Starter
Quoted: 8 Post(s)
I'm picking up my truck next weekend from the shop and my quest is will I have any issues loading the truck on a 20' tilt trailer. The entire deck tilts. I don't want to bring that trailer down there and not be able to load it. Thanks.
Macht87 is offline
post #2 of 32 Old 05-19-2017, 06:40 AM
DMc
Quoted: 209 Post(s)
The truck is over 20' long so it'll be hanging off the end of the trailer but the wheelbase is about 15' so it should fit. How tall is the front rail on the trailer? That'll determine how far forward you can position the truck. Since it's a tilt deck I'm guessing there are no fold up ramps to get in the way at the back?
2004 F250 4X4 CC SB
DMc is offline
post #3 of 32 Old 05-19-2017, 06:56 AM Thread Starter
Quoted: 8 Post(s)
I'm not sure. Looking at picking up the trailer on my way to get the truck since I don't have a trailer. Here are a couple of pics of the trailer.
ID:	623665   Click image for larger version
Macht87 is offline
post #4 of 32 Old 05-19-2017, 07:25 AM
DMc
Quoted: 209 Post(s)
That's a nice looking trailer. Certainly looks stout enough to get the job done. That winch may not let you pull the truck up on the trailer as far as you need to. If the front axle is 4' behind the winch, the back axle will be perched right on the end of the trailer with a fair amount of bed hanging off the back. Looks like it would be pretty close one way or the other!
ZMANN likes this.
2004 F250 4X4 CC SB
DMc is offline
post #5 of 32 Old 05-19-2017, 07:39 AM Thread Starter
Quoted: 8 Post(s)
Thx. It has a 8k winch and 2 - 7,000 Lb Dexter Torsion Axles. I forgot to include the picture of the side. It hay hydraulic jack also. Pretty much every option available according to the seller.
I just don't want to buy the trailer then not be able to put my truck on it. You guys know how it goes.
Macht87 is offline
post #6 of 32 Old 05-19-2017, 07:42 AM
ZMANN's Avatar
Quoted: 1784 Post(s)
I would check width cause your not driving over the trailer fenders on that unit
also, make sure it can handle 8,000 lbs the load is split pretty even between axles
and see if you need a trailer brake controller
zsargent and jokester00 like this.
We Miss you Ronnie
ZMANN is offline
post #7 of 32 Old 05-19-2017, 07:45 AM
jokester00's Avatar
Quoted: 105 Post(s)
Garage
I was wondering about the width myself...
-jokester
2005 F350 CCLB FX4 Lariat
ARP's with OEM gaskets
SCT SF3 - Currently running Gearhead 8K Tow Tune
Edge Insight CTS2 monitor
Edge EAS EGT probe
Edge EAS Fuel Pressure Sensor
DieselSite Coolant Filter
Blue Spring Upgrade
jokester00 is online now
post #8 of 32 Old 05-19-2017, 07:50 AM Thread Starter
Quoted: 8 Post(s)
Here is the build sheet he sent me. Please let me know if ANYTHING will prevent me from hauling my truck.
ID:	623689   Click image for larger version
ID:	623697   Click image for larger version
Macht87 is offline
post #9 of 32 Old 05-19-2017, 07:51 AM Thread Starter
Quoted: 8 Post(s)
I had the mechanic measure my truck and he said it's 80" wide.
Macht87 is offline
post #10 of 32 Old 05-19-2017, 07:55 AM
DMc
Quoted: 209 Post(s)
From that angle the winch doesn't look like it's mounted as high as I thought so I think you could pull it up closer to the front and still have some wiggle room at the back. Not sure where that would put you at for tongue weight though. Too bad you can't try it on before you buy!
Found this discussion. Don't know if it helps or not but......
Towing a Crew Cab Long Bed. - Diesel Forum - TheDieselStop.com
jokester00 likes this.
2004 F250 4X4 CC SB
DMc is offline
The Following User Says Thank You to DMc For This Useful Post:
