CTS 2 - Ford Powerstroke Diesel Forum
 3Likes
  • 1 Post By colo_dually
  • 1 Post By Sock Puppet
  • 1 Post By DMc
post #1 of 9 Old 05-18-2017, 03:02 PM Thread Starter
lilbraze38's Avatar
Quoted: 14 Post(s)
CTS 2
What does everyone monitor with there CTS 2? I want to know what the best things to monitor with it
lilbraze38 is offline
post #2 of 9 Old 05-18-2017, 03:08 PM
retaliashun's Avatar
Quoted: 33 Post(s)
Garage
Myself: ICP, IPR, EGT, EOT, ETT, Boost, Waste Gate Duty Cycle, IAT (until I put in fuel pressure sensor), Battery Voltage
'99
F250 SD 7.3L 249k Miles
Edge CTS 2
retaliashun is offline
post #3 of 9 Old 05-18-2017, 03:17 PM
The Silent Service
colo_dually's Avatar
Quoted: 30 Post(s)
I have a good thread on this subject, the type of monitor doesn't matter. Its listed in my sig.
If I was to run a CTS 2 only:
Boost, EGT
ICP, Ipw, Fuel Pressure
ECT, EOT, Trans. Temp.
Occasionally verify MAF compared to Boost and VGT Duty Cycle - Verify FICM Voltage at cranking - and run associated periodic checks.
If you end up with specific questions, let us know
jokester00 likes this.
2007 F-350 XLT 6.0L PSD Dually 'Jezebel'
TorqShift 4x4 CC/LB 4.30LS - Tow Boss Package
colo_dually is offline
post #4 of 9 Old 05-18-2017, 03:30 PM
Sock Puppet's Avatar
Quoted: 204 Post(s)
I just uploaded a picture of myself and use it as the background. That way I'm always monitoring something cool.
Rattlesnake18 likes this.
2007 F-350 4X4 CCSB, 6.0 PSD, ZF6 Manual Trans, 3.73s, Blue Spring, High-Idle mod, Mishimoto coolant filter, 6.4 starter, Genex mirror, Magnum RT steps, Leer 100R Shell, custom front bumper replacement, 4" Cat Back exhaust, JVC head unit with backup camera, '08+ towing mirrors and rear diff. cover, etc.
Sock Puppet is offline
post #5 of 9 Old 05-18-2017, 03:32 PM
Quoted: 204 Post(s)
On a serious note: ECT, EOT, Boost, FICM voltage, Battery voltage, EGTs, Fuel Pressure, and EBP. I think that's right. Wish I could watch fan speed.
post #6 of 9 Old 05-18-2017, 04:43 PM Thread Starter
lilbraze38's Avatar
Quoted: 14 Post(s)
Boost, EGT
What should EBP, ICP, IPW, and stuff like that be at? I've never monitored stuff like that
post #7 of 9 Old 05-18-2017, 06:49 PM
DMc
Quoted: 209 Post(s)
Go back up to colo_dually's post and click on the "Monitoring the 6.0" link in his signature. All your answers are there for the reading!
Sock Puppet likes this.
2004 F250 4X4 CC SB
DMc is offline
post #8 of 9 Old 05-18-2017, 07:30 PM
The Silent Service
Quoted: 30 Post(s)
EBP should be dependent on the engine load, boost level, tune and throttle. Around 2:1 ratio EBP to Boost is normal.
ICP and Ipw are throttle based, one is your HPOP pressure (or voltage on some trucks) and the other is the length of time your injectors are open. ICP will help you identify issues with the HPOP.
Some of what I monitor is for problem identification before a huge breakdown. Some help me monitor performance. The thread I have cover most of these things, but it may be time for me to update some of the date with what I've learned.
Thanks.
post #9 of 9 Old 05-19-2017, 11:29 AM Thread Starter
lilbraze38's Avatar
Quoted: 14 Post(s)
Thanks guys! I'm new to the whole monitoring thing and I've only had my truck for a year so I want to make sure that I'm doing everything right.
