Coolant filter add on - Ford Powerstroke Diesel Forum
 28Likes
post #1 of 52 Old 05-14-2017, 11:36 AM Thread Starter
desertranger's Avatar
Quoted: 14 Post(s)
Garage
Anyone add a pressure gauge to your coolant filter. Mine only reads about a quarter pound of pressure with a new Degas cap. Just curious about this
Sent from my 831C using Tapatalk
desertranger is offline
post #2 of 52 Old 05-14-2017, 11:47 AM
ZMANN's Avatar
Quoted: 1784 Post(s)
Try the old cap again
Or if you hear psi bleed off when you open the cap i would be willing to bet .25 psi on the guage is not accurate
We Miss you Ronnie
ZMANN is offline
post #3 of 52 Old 05-14-2017, 11:48 AM Thread Starter
Quoted: 14 Post(s)
Garage
Don't have the old cap anymore and autozone doesn't have the tester anymore
post #4 of 52 Old 05-14-2017, 12:00 PM
ZMANN's Avatar
Your truck is the tester.
If you drive it and go from cold to operating temps you should see more than 1/4 psi
If not you risk boil over at higher temps. Or your guage is wrong or you have a bad cAp , system leak
We Miss you Ronnie
ZMANN is offline
post #5 of 52 Old 05-14-2017, 12:15 PM Thread Starter
Quoted: 14 Post(s)
Garage
Does over heat or boil the coolant. But the gauge should read pressure correct ?
post #6 of 52 Old 05-14-2017, 12:24 PM
Fill it up again Dummy
mhatlen's Avatar
Quoted: 554 Post(s)
Garage
You should be seeing anything from 7-12 psi on the coolant pressure. Something is bad, either gauge or the cooling system leaking, or the cap is shot.
I use a liquid filled vibration proof 2-1/2" 15 PSI model.
desertranger likes this.
2006 F250 LARIAT CCSB 4X4
7" Icon/Carli Lift
ARP Studs, O-Ringed Heads
X4 PHP 65 HP Custom Tow Tune
Atlas40
4" SS exhaust
58K Miles on it
2000 Watts of McIntosh Bliss
mhatlen is offline
post #7 of 52 Old 05-14-2017, 12:26 PM Thread Starter
Quoted: 14 Post(s)
Garage
This what I got.
2-1/2" Oil Filled Pressure Gauge - Stainless Steel Case, Brass, 1/4" NPT, Lower Mount Connection 0-30PSI https://www.amazon.com/dp/B00G008JCU..._I3OpXBAS7M1DI
post #8 of 52 Old 05-14-2017, 12:40 PM
mhatlen's Avatar
Quoted: 554 Post(s)
Garage
Buddy something is a-miss here.
Change your coolant tank's cap FIRST.
Then pull that gauge out and look at the fine hole the water goes into. Make sure its not plugged up with debris. May need a needle to clear it out if plugged.
Then see what pressure you see when up to temps.
7" Icon/Carli Lift
Atlas40
4" SS exhaust
58K Miles on it
mhatlen is offline
post #9 of 52 Old 05-14-2017, 01:21 PM
ZMANN's Avatar
I dont like to install gauges in the fluid and horizontal
I preffer an air gap and high point
Here is what happens if you truly dont have psi
djmaguire and desertranger like this.
We Miss you Ronnie
ZMANN is offline
post #10 of 52 Old 05-14-2017, 01:50 PM Thread Starter
Quoted: 14 Post(s)
Garage
Thanks for all the info guys. BTW I am on a US submarine where all we do is study things like the affects of water under pressure except will deal with pressure of a couple thousand pounds and hundreds of degrees.
SparkyF250 likes this.
The Following 3 Users Say Thank You to desertranger For This Useful Post:
SparkyF250 (05-14-2017), ZMANN (05-14-2017)
