Rear lift springs - Ford Powerstroke Diesel Forum
Old 03-21-2007, 01:08 PM
Rear lift springs
I think I might win a pro comp stage 2 6" lift off ebay tonight for cheap. It's only the front lift though. Does anyone know about how much some rear leafs to match this front lift will cost? And to make it level, should I get 4" leafs or 6"?
Oh, and it's a 2005 diesel
Thanks
Old 03-21-2007, 01:42 PM
im fat and ugly
have you ruled out blocks? thats the cheapest way to go
Old 03-21-2007, 02:22 PM
Yes blocks. Much cheaper and doesn't affect the ride. If it's a 6" front lift you want a 4" block to level it out. Most manufactures make a rear block 4" kit that includes the blocks and the u bolts. You may also need to get a rear driveshaft shim kit.
Old 03-21-2007, 03:10 PM
5 or 6" lift springs will run between 300-450, get the greatest amount of leaves you can as most replacement springs will not have the same load capacity, they will however ride better. Whatever you deciede you must get the driveshaft shim kit!
Old 03-21-2007, 03:46 PM
Thanks, if blocks are cheaper then thats probably what I will get. I hate to admit it but it really wont see much offroading. The lift would just be for looks.
How much tire would 6" clear? I already have a 20" tall, 10.5" wide rim and would like to stick with them.
Also, how does the driveshaft shim kit work?
Thanks!
Old 03-21-2007, 04:27 PM
I cannot find any info or prices on a 4" block, can someone point me in the right direction here?
Old 03-21-2007, 06:21 PM
You probably won't find to many listed because most people need a whole kit. That doesn't mean they don't sell them though. You will just have to call.
Try Tuners, Suspensions, Exhaust and other performance parts. DiscountPowerParts.com
They carry procomp.
The shim kits drops the rear driveshaft hanger bearing down so the two shafts are inline. There is no cv joint between the two halves so the slightest angle will make it vibrate. The kit comes with several different thicknesses of shims and you add or remove until the vibration is gone. Mine came with a recommendation of where to start and it was perfect the first time.
