Help... Rodent made a nest under the vacuum pump - Ford Powerstroke Diesel Forum
 3Likes
  • 2 Post By G8orFord
  • 1 Post By JustinOOO9
post #1 of 9 Old 04-18-2017, 05:40 PM Thread Starter
Garage
Send a message via AIM to blownnjucied94
Hey guys,
I need help with part numbers and/or diagrams for the vacuum lines around the vacuum pump... Something built a nest under mine and destroyed the vacuum lines. They chewed them off at:
- pump
- two lines at 4x4 lockout switch
- two lines at the vacuum can
I was able to unplug at the union a black line that parallels the grey one from the heater valve on top of the valve cover. This black line looked like it may have went to the 4x4 switch and routes towards the fire wall along with the one the one from the heater valve on top of the valve cover. The other one I was able to unplug from the union looks like it went from the 4x4 lockout switch down to the front axle.
What I cannot figure out is the routing between the pump, and vacuum can. I am thinking I am either missing another line entirely or one of the connection points on the pump, can, or 4x4 switch has a T on it.
Basically I have the following:
- intact union with a black line headed towards the fire wall running parallel to a grey line that runs from the heater valve on top of the valve cover. The chewed up side of this line looked like it went to the 4x4 selector motor on the fender.
- intact union on a black line that heads down to the frame rail towards the front axle. Again it looked like the chewed up side of this line may have connected to the 4x4 selector motor.
- The line coming off the vacuum pump was chewed off.
- the two lines coming off the vacuum can were chewed off.
I would much rather buy the vacuum harness from the factor vs. piecing it back together, as I am a bit anal-retentive.
The also took out the harness that plugs into the harness on the fire wall and plugs into the bottom of the heater box. I assume this is the blower motor resister harness? and the single larger (6 or 8 gauge) yellow wire that runs from the battery cable harness up to a single plug on the harness by the firewall.
I'll try to post some pics of the carnage...
Red 94 Lightning, #10 Born Jan 25, 1994
10psi of S-Trim / 75hp Nitrous / Hughes 2500 Stall
Red '92, F-150 4x4 on 38's
White 2005 F-350 6.0L CrewCab - IPR EGR Delete; Studded w/ OEM HG; Tuned by Innovate via SCT
2013 Harley FXDB - Pearl Blue
With the addition of the bike, my rides are Red, White & Blue!
blownnjucied94 is offline
post #2 of 9 Old 04-18-2017, 06:03 PM Thread Starter
Garage
Here are some photos of the what they destroyed...
ID:	616066   Click image for larger version
ID:	616074   Click image for larger version
ID:	616082   Click image for larger version
post #3 of 9 Old 04-18-2017, 06:41 PM Thread Starter
Garage
I might have found the vacuum harness, but cannot confirm yet. Anyone?
F81Z-7A784-BB
or
7C3Z-7A784-C
post #4 of 9 Old 04-19-2017, 05:05 AM
Quoted: 132 Post(s)
That sux man! My bro had a squirrel problem at his house which ate thru his wiring harness on his truck and the rubber propane lines on his RV. Needless to say, he went on a mission to seek and destroy them varmints.
2017 F350 DRW King Ranch FX4
2004 F350 6.0 - Traded 2/4/17 (Pity the fool who bought it)
jd4010 is offline
post #5 of 9 Old 04-19-2017, 05:34 AM
G8orFord's Avatar
Quoted: 818 Post(s)
Garage
@fordsvtparts can probably help.
fordsvtparts and jokester00 like this.
Dexter
2004 F-250SD Lariat CCSB FX4 SRW
DashCommand on PLX Kiwi2 with iMFD
SCT X4 w/custom tunes (currently TSD MPD)
FICM from Ed
PHP FICM tuner (currently Atlas80)
KC Stage 1.5 Turbo
Blue Spring update
IPR Coolant Filter w/manifold
Rotella ELC Coolant (CAT EC-1 rated)
BPD EGR Cooler
New (03/23/14) OEM Oil Cooler - (backflushed 05/10/15 @ ~40K & 07/03/16 @ ~70k)
G8orFord is offline
The Following 2 Users Say Thank You to G8orFord For This Useful Post:
fordsvtparts (04-19-2017)
post #6 of 9 Old 04-19-2017, 06:21 AM
Rolfsted's Avatar
Quoted: 34 Post(s)
Start putting traps on the tires. I've caught over a hundred last two winters.
Sent from my Touchpad using Tapatalk
Rolfsted is offline
post #7 of 9 Old 04-19-2017, 07:20 AM
JustinOOO9's Avatar
Quoted: 521 Post(s)
Garage
I got my vacuum pump, and reservoir from rockauto. I didn't know about ford svtparts at the time though.(don't even bother calling the local dealer they are rip offs) Its been a year and fine so far.
Fordsvtparts and sunriseford both in the vendors will hook you up
fordsvtparts likes this.
currently-1999 F250 SBRB 4X4 7.3, 6.0 trans cooler, 08 mirrors, AIS Intake, Hydra, Level kit, 33s.
-2004 F350 CCLB 4x4: Sinister Race solutions kit, CAT ELC Edge CS, SCT SF3, PHP Ficm programmer, Procomp, Rough country, and Nitto goodies.
-2004 excursion, banks exhaust, 03 turbo, aem intake. 4in lift, 35in kumhos
-2006 f350 king ranch, aem intake, 10 in fabtech, 40in tires, sct tunes.
Interested in learning something new?
Justin,
2F071 USAF 2008-2014
JustinOOO9 is offline
The Following 2 Users Say Thank You to JustinOOO9 For This Useful Post:
post #8 of 9 Old 04-19-2017, 05:49 PM
fordsvtparts's Avatar
Quoted: 81 Post(s)
Holly crap!
Here's a link to our Motorcraft pumps
Vacuum Pump | Genuine Ford | 6C3Z-2A451-A : AutoNation Ford White Bear Lake | Parts & Accessories
We are Autonation Ford of White Bear Lake selling all OEM Ford parts at employee prices (formerly Tousley)
Call us at 1-800-328-9552 (be sure to mention this website when calling)
OR check out our website
Try out Ford's website as well!
I'll meet or or beat any price on OEM parts
fordsvtparts is offline
post #9 of 9 Old 04-19-2017, 06:30 PM
Quoted: 42 Post(s)
I had a pack rat once took me a week to kill that SOB ... With a 2 inch wooded dowel
06 F350 KR Promaxx Heads & ARP Studs,Deleted
8"Procomp 2.75 XX75 Dual Coil-overs
MKW 22x11 M26 -24 Offset,Toyo MT 37x13.5x22
MBRP Straight 4 Inch Exhaust,MBRP Up-Pipe
Fabtech Dual Sterring Stabilizer
Pro Comp Traction Bars
SCT Live Wire & Probe
Sinister Coolant Filter System
BPD Water Pump,Mishimoto Rad
Rudy's Diesel CAI 150.00 Cheaper than Sinister's
7.3L Fan, 6.4L Banjo Bolts Blue Springs
HornBlasters Conductor's Special Model 240 Train Horns
Synthetic with Hotshot Additive
Alpine W960 Touchscreen W/T Backup Camera
JL Audio Stealthbox Center Console W/T Rockford Fosgate AMP
2012 Can-am Outlander 800R Camo
2005 Excursion 6.0L
"I'm out old man. I'm just a pecker-wood who lives in the woods with too many guns. Ya happy?"
BridgerMT is offline
