Oil Cooler Replacement - Ford Powerstroke Diesel Forum
 8Likes
post #1 of 14 Old 04-18-2017, 02:38 PM Thread Starter
Quoted: 3 Post(s)
Planning to replace my oil cooler since my temps are way off. What all parts will I need? I plan to strictly replace the oil cooler since I have an egr delete already installed. So far I have:
  1. Oil Cooler
  2. Turbo Hardware
  3. Intake Manifold Gasket
I plan to add an coolant filter and do the blue spring mod also. Thank you for the help!
arayray94 is offline
post #2 of 14 Old 04-18-2017, 03:19 PM
djmaguire's Avatar
Quoted: 704 Post(s)
Garage
I'd add a turbo o-ring kit (3C3Z-9T514-AG) to the list. No sense not replacing those as long as you are messing with the tubes. You may also want to check your screen of your IPR valve or just replace it on principle.
partyman97_3 and jokester00 like this.
2004 F550 CC Lariat
BPD oil cooler relocation and upgraded EGR cooler (spooled), BPD oil bypass filtration, aFe Magnum Force CAI, Mishi radiator, EC1 ELC, XDP coolant bypass filtration, '08 trans pan/filter, PTP direct clutch solenoid, blue spring, 6.4 starter, MBRP y-pipe, BD boots/clamps, '05 intake elbow, ccv reroute, Torque Pro + OBDLinkô LX, Autometer EGT
djmaguire is offline
post #3 of 14 Old 04-18-2017, 04:35 PM
Sock Puppet's Avatar
Quoted: 168 Post(s)
Is the oil cooler you have an OEM part?
jokester00 likes this.
2007 F-350 4X4 CCSB, 6.0 PSD, ZF6 Manual Trans, 3.73s, Blue Spring, High-Idle mod, Mishimoto coolant filter, 6.4 starter, Genex mirror, Magnum RT steps, Leer 100R Shell, custom front bumper replacement, 4" Cat Back exhaust, JVC head unit with backup camera, '08+ towing mirrors and rear diff. cover, etc.
Sock Puppet is offline
post #4 of 14 Old 04-18-2017, 05:10 PM
PyroTekRob's Avatar
Quoted: 312 Post(s)
I just bought the BPD Heavy Duty kit w/filter relocation.
Sent from my LG-H918 using Tapatalk
Sock Puppet likes this.
2006 F250 Amarillo 4x4 CCLB - 210,xxx
SCT Livewire TS - Tunes from Vivian (Eco, Tow, Tow w/ JB, Looney)
DrawTite Flip Over Goose
Leveling Kit - Wildpeak AT3Ws 325/75R18
Sinister Diesel Coolant Filter
Garrett Powermax Turbo
DC Power Engineering 185amp Alt.
BPD Heavy Air Oil Cooler
BPD EGR
LED bulb upgrades.
Curt Class V - Air Lift Load Level 5k Ult - Wireless Compr
PyroTekRob is offline
post #5 of 14 Old 04-18-2017, 05:29 PM
ChrisSki's Avatar
Quoted: 151 Post(s)
Fumoto F-108n Coolant drain valves with a 113 O-Ring and Monster blue tape to seal it. Not sure the hose size, but if you bring the valves to home depot, get the wire enforced PVC tubing. To go with it, an IPR coolant gasket.
Also, for the coolant filter, IPR so it's full flow and reusable. To get full flow prior to the oil filter, than a remote oil cooler relocation kit.
Will you replace the EGR? If so BPD. If you delete, just be sure you want to pass any emissions test.
A few of the shops will do oil cooler gasket kits.
2005 F250
172,000 Miles
Bullet Proof HD Oil Cooler w/ Cold Weather Kit
Bullet Proof EGR
ChrisSki is offline
post #6 of 14 Old 04-19-2017, 01:19 PM Thread Starter
Quoted: 3 Post(s)
I am going with an OEM cooler.
Thanks for the suggestions! I will definitely check out the drain valve! I am going with a sinister filter since I am on a budget. Wish I could bulletproof it but not at this time.
post #7 of 14 Old 04-19-2017, 04:02 PM
djmaguire's Avatar
Quoted: 704 Post(s)
Garage
If "going with" means that you haven't bought it yet, go with the XDP coolant filter instead. Better hoses and better price.
XDP 6.0L Coolant Filtration System XD143
Use the code "DIESEL10" at checkout for 10% off. You will not regret it.
2004 F550 CC Lariat
post #8 of 14 Old 04-19-2017, 04:08 PM Thread Starter
Quoted: 3 Post(s)
Awesome, are those filters good or can they be swapped for better?
post #9 of 14 Old 04-19-2017, 04:29 PM
Beerent93's Avatar
Quoted: 16 Post(s)
Bro just take a good hard look at everything you got going on, when I did mine the parts list grew and grew. It's not a hard job so much as it's a time consuming job. Reference Diesel Tech Ron on you tube for Excellent tips and tricks, I must have watched his video at least 20 times while I was doing mine. Just look for worn parts, Mine got new upper and lower hoses, thermostat, heater control valve and Serpentine belt while I was in there. I bought a VGT pig tail and well it's still sitting on my Kitchen table...LOL
Beerent93 is offline
post #10 of 14 Old 04-19-2017, 04:55 PM
djmaguire's Avatar
Quoted: 704 Post(s)
Garage
The filters that come with it are fine but you can sub a whole bunch of others. It's a standard coolant filter thread size.
Here is a link to when I did my relocation and some other things that you aren't doing. Still, there is enough the same that it may help.
BDP Oil Cooler Relocation and some miscellany
You also may see some things on my list that you want to add to yours. @Beerent93 mentioned belts, for instance. Good suggestion. I did mine.
SparkyF250 likes this.
2004 F550 CC Lariat
