new 6.0 owner - Ford Powerstroke Diesel Forum
 2Likes
  • 1 Post By G8orFord
  • 1 Post By 208f350
post #1 of 6 Old 04-17-2017, 09:42 AM Thread Starter
new 6.0 owner
Hello How is everyone doing I am a new proud owner of my 2006 F350. I have wanted a diesel for a while and have been reading and doing a lot of research on the 6.0 and with a lot of hate coming form my Cummins and duramax friends I bought my baby. It is 2006 f350 extra cab with 135k miles already has the head studs and egr delete 8in Pro comp lift with the longer trailing arms. I bought the SCT livewire for it. and the blue spring. now a few things What should I or shouldn't I do with it. Thinking about doing a wicked wheel on the turbo. Ill admit not totally impressed with the live wire canned tunes. I swear it was hitting 25PSi and now its hitting 20 I have test drove several that were deleted and that were hitting 20 and would spank my truck. She runs great starts right up but feels low on boost and smokes a fair amount when getting on it. anything else people recommend doing with the trans or anything. thanks for every ones time.
ID:	615738   Click image for larger version
208f350 is offline
post #2 of 6 Old 04-17-2017, 06:31 PM
G8orFord's Avatar
Quoted: 991 Post(s)
Garage
First of all, set aside a couple of hours a day for the next week or so to read through the stickies at the top of this page and the other sub-forums under the 6.0 general heading. Get yourself familiarized with the 6.0 and the other aspects of your truck by reading here and then studying your truck itself. You'll answer some of your questions by reading and you'll find you have a lot more once you're done. As far as the wicked wheel, there are better options. Your low boost very likely is due to a leak on one or both sides of the turbo, but could be many things. Do your research and ask your questions, but don't expect a lot of spoonfeeding. Most all of us love to help those that are willing to help themselves.
john galt likes this.
Dexter
2004 F-250SD Lariat CCSB FX4 SRW; SCT X4 w/custom tunes (currently
MPD)
DashCommand on PLX Kiwi2 + iMFD with EGT & Fuel/Oil Pressure
Stage 1.5 Turbo;
Stage 1 HPOP;
FICM;
FICM Tuner (currently Atlas40)
VK688 Oil Cooler Relocate;
EGR Cooler;
Water Pump;
Coolant Filter
Blue Spring update; Rotella ELC Coolant (CAT EC-1 rated); 6.4 Transmission Pan and Filter
G8orFord is offline
post #3 of 6 Old 04-17-2017, 06:57 PM
john galt's Avatar
Quoted: 1501 Post(s)
as was said read up in the stickies especially on monitoring and bulletproofing
I have the cts and love it but if i were buying my truck today i would have the torque app and a dedicated android
this was pretty much the advice i followed when i first got my truck
Things to consider about owning a 6.0L
I like mead
early 04 f350 6.0 cclb lariat sr
Bulletproof oil &egr, elc, sct x3, edge CTS, afe intake, blue spring, t-500, MTW stage 2, Vivians looney, 305 x55x20 bfg at ko's, 4 inch cat back, 4"BDS fox shocks and steering stabilizer, tri pilar gauge set, coolant filter, riff raff boots, new headliner, 7 inch touch screen w/back up, new carpet, near whole new interior,
FederalOwnershipRespectfullyDeclined
john galt is offline
post #4 of 6 Old 04-18-2017, 06:41 AM Thread Starter
thanks I have read and read many threads and post, and I am not afraid of doing my own research I mainly asked about the boost because some people say its ok and others say its low. the problem is never know what on to belive. I had to replace my thermostat because it was stuck open my water temp holds solid at 190 and my oil temp is right within 189 192. those temps seam a lot closer then everyone elses. the truck already has a lot of work done head studs egr deleated. don't know why they wouldn't do the oil cooler while they were there and those temps seam good. main issue was wondering weather 20lbs is good or not good and is 12 mpg good or not good.
208f350 is offline
post #5 of 6 Old 04-18-2017, 07:43 AM
G8orFord's Avatar
Quoted: 991 Post(s)
Garage
20 psi is not terrible, but it's also not "good". A properly functioning 6.0 shouldn't have much problem building between 25 and 30 psi. I think I read somewhere the "spec" was 27 psi. It's hard to say if 12 mpg is good or not. Not sure what your gearing, tire size, load and and driving style is, but my first thought is that is a little low. You are lifted and it appears the tires are a bit over-sized from stock, so that will contribute some. When I first got my CCSB, I was getting very close to averaging 18 mpg with mixed driving. I have lost about 2 mpg over the past two years and struggle to get 16 mpg now. Haven't figured it out yet, but I believe it is related to the same reason I can only get about 23psi of boost myself. The current line of thinking is a weak HPOP.
Dexter
MPD)
Stage 1.5 Turbo;
Stage 1 HPOP;
FICM;
EGR Cooler;
Water Pump;
Coolant Filter
G8orFord is offline
post #6 of 6 Old 04-18-2017, 10:00 AM Thread Starter
ya im going to do a pressure test on my boost when the weather straightens out. I go the sct tuner for it idk if I like it yet or not the power is good but not a fan of the monitor and the workings of it vrs my friends edge. yes it is lifted with bigger tires.
208f350 is offline
