Where to start? - Ford Powerstroke Diesel Forum
post #1 of 7 Old 11-24-2009, 08:16 AM Thread Starter
Where to start?
Hi all,
Well I'm about to bite the bullet on a 2005 F250 Fx4 w/ 95k miles and I was hoping you all could give me a run down on things to do(and not to for that matter). I didn't get a real good idea of when the last time all fluids were changed so I think as good measure I'm going to change all oil, tranny and diff fluids. If it's not too difficult, I plan on changing both fuel filters also. I also plan on checking the brakes since it's lifted and I'm sure that puts additional strain on the brakes. Can you list some additional things I should do when first taking ownership? Also, things I should/should not do during driving (for example I found out through reading some posts that it's not good to let it idle for a long time).
Just looking for a little insight for someone that is new to diesels.
Thanks
Brian
ZCHF is offline
post #2 of 7 Old 11-25-2009, 07:59 AM Thread Starter
Anyone have any suggestions...or even a link to somewhere that posts similar information?
ZCHF is offline
post #3 of 7 Old 11-25-2009, 08:33 AM
topdwg's Avatar
I think you're off to a good start. Change all the fluids / filters and I think you'll be set. Changing the fuel filters is easy. Hardest part is not getting it all over you. As for idleing it's extended ones you have to worry about. If you have the new flash your turbo after 5 minutes will work the vanes to help in them not getting gummed up. Speaking of flashes, that something you might want to do. Here it cost $85 at the dealership, and it's something that could help with cold starts and help in prolonging the life of your FICM.
2012 F-350 SRW King Ranch
SOLD - 2004 Lariat F-250 4x4
6.5 Pro Comp Lift W/ Fox Shocks, DeeZee Tool Box, 08 Diff. Cover, 37x13.5/20's Pro Comps, Zoodad Mod, SCT w/custom tunes, 4 in EX., AFE Intake, ARP, Recon Lights, High Idle Mod, RCD EGR Delete, Fumoto Valve, Oil Bypass Kit, 03 Turbo, Yukon Gears, Farmboy Stage II Traction Bars, Dieselsite Coolant Kit, Amsoil, HIDS, Edge Insight CS, PHP FICM
topdwg is offline
post #4 of 7 Old 11-25-2009, 09:03 AM Thread Starter
Do the 05's have the FICM problems also? Also, will a dealer do an upgraded reflash if there is an Edge programmer installed?
Thanks again!
ZCHF is offline
post #5 of 7 Old 11-25-2009, 09:22 AM
MoyockPowerstroke's Avatar
Definateky the three "F"s Fluids, Filters, Fuel....Change the fuel filters asap...probably thee most important set of filters on the truck and you do not want these to be overdue 10k max. Change your oil and oil filter every 5,000 use 5w-40 syn if you can. Don't buy fuel from just anywhere...top fuels even use cetane booster will help. Change you external tranny filter every 30K,,,may not have been changed...so change it anyway. Tranny fluid should be red and clearly smell of sulfer from the ad packs in Mercon Sp...speaking of which...use only Mercon SP for the transmission...check the smell, you'll know what I'm talking about. Take a good look at your coolant...you would be surprized...some people (2nd owners) have found coolant other than Gold coolant. It has to be either Motorcraft Premium Gold or Valvolines Zerex G-05. Flush your brake fluid. If you have an aftermarket air filter check it to ensure its equal to or better than the OEM Donaldson. Welcome aboard.
'05 6.0L, 128k miles, Racor CCV6000 Filter, Oil Bypass Filter, Fumoto drain valves, Coolant Filter, ZooDad, HighIdleMod, BullyDog 4" TB, VXCF9 Strat, Edge Insight Gauge, Torque App, Fuel Press Gauge, Upfitters, 4" SJ lift w/Bilstein 5100's, Ride-Rite Airbags, Rough Country Dual Stabilizers, 24" Wipers, '08 Rear Diff cover, Mobil1 Syn 5W-40, 6.4L banjos, Blue Fuel Spring, SS HPOP screen, '08 Mirrors, Zerex ELC.
MoyockPowerstroke is offline
post #6 of 7 Old 11-25-2009, 09:37 AM Thread Starter
Thanks guys. Yeah, I'm definitely changing all fluids...I just ordered some Opti-Lube XPD too. Is there a good site to get all the fluids and filters from?
ZCHF is offline
post #7 of 7 Old 11-25-2009, 07:52 PM
Diesel Filters,Additives,brake rotors, and brake pads for Chevy, Dodge and Ford Diesel Trucks
