Insight users-What is your Mod Volts ouput readings? - Ford Powerstroke Diesel Forum
post #1 of 3 Old 11-23-2009, 07:20 PM Thread Starter
MoyockPowerstroke's Avatar
Running the Edge Insight...and checking my Mod Volts ouput with the following readings. Can someone compare my numbers with either their digital or analog gauges?
Initial Start-up volts average between 11.2v and 12.2v (for a duration of 56 seconds...assume while Glow-Plugs are cycled)...then it ramps up to between 13.5v and 13.7v during normal driving and idle...the numbers flucuate pretty violantly...I would have thought they would be more stable. ?? Any advise or assistance greatly appreciated. Thanks.
'05 6.0L, 128k miles, Racor CCV6000 Filter, Oil Bypass Filter, Fumoto drain valves, Coolant Filter, ZooDad, HighIdleMod, BullyDog 4" TB, VXCF9 Strat, Edge Insight Gauge, Torque App, Fuel Press Gauge, Upfitters, 4" SJ lift w/Bilstein 5100's, Ride-Rite Airbags, Rough Country Dual Stabilizers, 24" Wipers, '08 Rear Diff cover, Mobil1 Syn 5W-40, 6.4L banjos, Blue Fuel Spring, SS HPOP screen, '08 Mirrors, Zerex ELC.
MoyockPowerstroke is offline
post #2 of 3 Old 11-23-2009, 09:13 PM
I have the insight also, and your readings on the volts are the same as mine.
I checked my volts at the battery with it running and they were 14-14.4.
I think that where ever the insight gets its signal from is a little lower.
I don;t worry about it because i know the batterys are getting full charge.
swaan is offline
post #3 of 3 Old 11-24-2009, 04:26 AM Thread Starter
Yeah, I should hook up a DVOm while running or @ 2000rpm and see what the batteries are looking like.
Any others out there have readings to compare with mine?
