Engine compatability - Ford Powerstroke Diesel Forum
post #1 of 7 Old 03-20-2017, 11:41 AM Thread Starter
Quoted: 2 Post(s)
I have a 2003 F350 with a 6.0 that destroyed itself. I have access to a 2007 6.0 with the harness and ECU. What problems (electrical, transmission, fuel pump) might I encounter in trying to swap this engine into my rig?
Thanks,
Boyd
Osprey is offline
post #2 of 7 Old 03-20-2017, 11:59 AM
shenanigans
junior125's Avatar
Quoted: 1574 Post(s)
Garage
transmission is the same, fuel pump is the same
how many miles on the possible donor?
Mike
2005 CCSB F250 4X4
junior125 is offline
post #3 of 7 Old 03-20-2017, 01:38 PM Thread Starter
Quoted: 2 Post(s)
77K miles. Could this turn out to be an electrical wiring nightmare?
Osprey is offline
post #4 of 7 Old 03-20-2017, 03:11 PM
Master_Chase's Avatar
Quoted: 391 Post(s)
I would use the electronics of the receiving vehicle because a couple of things were different like the instrument cluster (05+ are digital)
Early 2003 6.0 Excursion fully bulletproofed, 155/30 injectors, KC Stage 2, and a lot of other stuff. Thanks to everyone on the forum I have learned a lot.
The EGR does to your engine what smoking does to your lungs.
Remember you can always improve on a design until the EPA gets involved.
Master_Chase is offline
post #5 of 7 Old 03-20-2017, 06:02 PM
Powerstroke Techie
Quoted: 383 Post(s)
I believe the 07 engine harness can be retained.
You will need an 05+ lower rad hose to accommodate the outlet on your 07 front cover tho
the richest ones are not those who have the most, but those who need the least
**i don't use capitals. deal with it**
kaya is offline
post #6 of 7 Old 03-21-2017, 08:05 AM
6.0 Powerstroke n00b
krazyk's Avatar
Quoted: 50 Post(s)
Garage
We essentially just did this but it was a 2006 engine into a late 2004 truck.
2006 6.0 F250 FX4
krazyk is offline
post #7 of 7 Old 03-21-2017, 10:42 AM Thread Starter
Quoted: 2 Post(s)
Krazyk, did you have to rewire on the passenger side of the firewall?
Osprey is offline
