Exhaust brake Ford 6.0 - Ford Powerstroke Diesel Forum
post #1 of 9 Old 03-19-2017, 06:33 AM Thread Starter
lcgoatboy's Avatar
Quoted: 5 Post(s)
Anyone hear of an exhaust brake for the Ford 6.0. or will it even be needed with a 6-speed manual. My friend is buying this 2004 F450 standard.
https://nashville.craigslist.org/ctd/6023714548.html
Thanks
1982 BJ60 3.4 Diesel
2006 F350 PSD SD
lcgoatboy is offline
post #2 of 9 Old 03-19-2017, 09:31 AM
Master_Chase's Avatar
Quoted: 400 Post(s)
There are companies that sell exhaust brakes but before you buy one try getting a custom tune that enables turbo braking.
Early 2003 6.0 Excursion fully bulletproofed, 155/30 injectors, KC Stage 2, and a lot of other stuff. Thanks to everyone on the forum I have learned a lot.
The EGR does to your engine what smoking does to your lungs.
Remember you can always improve on a design until the EPA gets involved.
Master_Chase is offline
post #3 of 9 Old 03-19-2017, 09:43 AM Thread Starter
lcgoatboy's Avatar
Quoted: 5 Post(s)
I have read about turbo braking and hear that it can be harmful for the valve train?
post #4 of 9 Old 03-19-2017, 12:50 PM
doubleslottedflaps's Avatar
Quoted: 28 Post(s)
I have pulled many 10,000-12,000 pound loads through the mountains and never needed a lot of brake. I do not have an exhaust brake and dont plan on buying one. I use Performance Friction Z series brake pads with the original rotors on all 4 corners. Make sure your trailer brakes are in good working condition and use a Tekonsha Prodigy or factory ford installed brake controller. 2006 F350 6.0 6 speed schtick !
doubleslottedflaps is offline
post #5 of 9 Old 03-19-2017, 12:58 PM
Quoted: 400 Post(s)
If the backpressure caused by the turbo can damage the valve train then the increased back pressure from a true exhaust brake will cause other problems but seeing how I've never read of an exhaust or turbo brake causing problems I think you're safe.
FYI I run the turbo brake 24/7 and have been for 20K miles before that I only had it on when I had my tow tune loaded which wasn't very often.
If you've never tried one you don't know what your missing, I have the turbo brake feature on even when I'm unloaded and I really like it.
The Following 2 Users Say Thank You to Master_Chase For This Useful Post:
lcgoatboy (03-19-2017)
post #6 of 9 Old 03-19-2017, 01:08 PM
Quoted: 28 Post(s)
How do I get a turbo brake ?
post #7 of 9 Old 03-19-2017, 01:25 PM Thread Starter
lcgoatboy's Avatar
Quoted: 5 Post(s)
I sell the prodigy controller,yes they are great. Better to have the factory Ford,they are a prodigy integrated to the pcm. This is what Teckonsha has told me.
2006 F350 PSD SD
post #8 of 9 Old 03-19-2017, 01:47 PM
Quoted: 400 Post(s)
Custom tune or BDs tap shift are the 2 ways I know to enable it, I have it enabled by custom tuning.
post #9 of 9 Old 03-19-2017, 08:22 PM
Quoted: 83 Post(s)
Sct X4 has the as a selectable feature
Ross
2006 f-250 CCSB king ranch diesel 4x4. Stock w/ air bags, rancho 9000s, and SCT Tuner
Rossterman is offline
