Do i need friction modifier? - Ford Powerstroke Diesel Forum
post #1 of 7 Old 11-23-2009, 09:24 AM Thread Starter
dmalmgre's Avatar
I'm changing out my rear diff fluid and I'm using Lucas 75w140 Synthetic. It says on the bottle that I don't need any additives. I've also heard if you use synthetic lube you don't need to use it. Anyone care to enlighten me?
2004 Ford F250 SD Crew Cab 6.0 PowerStroke 4x4
-BPD Oil Cooler
-BPD EGR Cooler
-SCT Livewire TS
-SRL Tune (Gearhead Performance)
-Blue Spring Mod
-Fabtech 8" lift (dual stabilizer, dual front/single rear Fox Racing shocks)
-20" Weld Racing Wheels
-37" Toyo Open Country Tires
dmalmgre is offline
post #2 of 7 Old 11-23-2009, 09:28 AM
Goose350's Avatar
This is correct. If it says you don't need additives then you wont need them
The Mullet Mod
Stock 2005 F-350 4x4
*Afe Intake
*4" TB Exhaust
*Scangauge
*SCT
oil bypass
water pump
*Tuned FICM
Goose350 is offline
post #3 of 7 Old 11-23-2009, 09:29 AM Thread Starter
dmalmgre's Avatar
Just making sure, didn't wanna trash my clutches.
-BPD Oil Cooler
-BPD EGR Cooler
-SCT Livewire TS
-Blue Spring Mod
dmalmgre is offline
post #4 of 7 Old 11-23-2009, 06:35 PM
dmalmgre,
I'm getting ready to do mine also...got a new Oasis diff cover with magnetic drain and fill plug and a "Lube Locker" gasket. I'm gonna run the Mobil 1 75-140 synthetic. Are you going to clean the inside with non-chlorinated brake cleaner? Let me know how it goes.
Mike
2007 F-250 CC Lariat FX4 4x4
6.0L PSD
4" MBRP exhaust
high-idle mod (PTO)
UnderCover tonneau
Oasis Diff cover w/LubeLocker gasket
Bullet through bedrail mod
rinnels69 is offline
post #5 of 7 Old 11-23-2009, 06:36 PM
Tony V's Avatar
I used royal purple and it already had the additive in it. There is a few guys on here that says thats bad when it already has it, but it works for me.
2000 F-250 216k- smoke much?
Facebook: Anthony VanCamp
Add me if you'd like
Tony V is offline
post #6 of 7 Old 11-23-2009, 07:39 PM Thread Starter
dmalmgre's Avatar
Nah I've never had to before. Just going to drain and refill. Thanks for the info guys!
-BPD Oil Cooler
-BPD EGR Cooler
-SCT Livewire TS
-Blue Spring Mod
dmalmgre is offline
post #7 of 7 Old 11-24-2009, 09:18 AM
With an '03 your clutches are probably toasted anyway, so they won't be grabbing much. If you do notice them grabbing in corners add 2oz modifier at a time until it goes away, add too much and your LS is worthless (stock one is anyway).
2012 F-150 XLT Ecoboost SuperCrew 6.5' 4x4
cartmanea is offline
