Coolant flush - Ford Powerstroke Diesel Forum
 3Likes
post #1 of 13 Old 03-18-2017, 05:02 AM Thread Starter
Beerbait's Avatar
Quoted: 73 Post(s)
Coolant flush
My truck has almost 90000 miles and I can't tell if the coolant has ever been changed. So I will be doing a coolant flush and change. I understand the process and want to do this right. Being new to diesel and my f250 I have a question. In other posts it mentions a block plug. Where do I find the plugs? Are they reusable or do I need to have new ons ready to go when I start?
As always thanks in advance for your help.
Beerbait
03 6.0 XLT
ex cab 4x4 Leather
automatic Egr delete
Molon labe
Beerbait is offline
post #2 of 13 Old 03-18-2017, 06:13 AM
TwinExcursions's Avatar
Quoted: 44 Post(s)
Garage
Check out maintenance forum. Really good pdf file under flushing with locations of these plugs c/with pictures
Sent from my SM-G930W8 using Tapatalk
05 Eddie Bauer
Blue spring/HPO updates/turbo oil pipes upgraded
EGR delete
IC to manifold pipe upgraded to steel pipe
58v FICM
SCT with Gearheads tunes
S&B stage 2 cold air
SD coolant bypass filter
Updated oil cooler
Edge Insight CTS2 c/w EGT sensor
ARP head studs
BD Diesel 7.3 fan clutch
4" Magna Flow stainless turbo back, cat empty shell
Heavy duty alternator (230A)
Buckstop bumper c/w Warn 16.5 winch
Warn Hubs, Eaton posi front/rear diffs
Toyo M55 285/75Rx16
TwinExcursions is offline
The Following User Says Thank You to TwinExcursions For This Useful Post:
Beerbait (03-18-2017)
post #3 of 13 Old 03-18-2017, 06:22 AM
Quoted: 44 Post(s)
Garage
Sorry under tech files then maintenance info, second sticky on flushing
05 Eddie Bauer
EGR delete
58v FICM
Updated oil cooler
ARP head studs
Toyo M55 285/75Rx16
post #4 of 13 Old 03-18-2017, 09:05 AM
jokester00's Avatar
Quoted: 84 Post(s)
Garage
I would get something to monitor the truck and check your deltas first. If they're good, I would flush it with distilled water only - no chemicals. And yes, the block drain plugs are reusable.
-jokester
2005 F350 CCLB FX4 Lariat
ARP's with OEM gaskets
SCT SF3 Tuner
PHP Atlas 40 FICM Tune
Edge Insight CTS2 monitor
Edge EAS EGT probe
Edge EAS Fuel Pressure Sensor
DieselSite Coolant Filter
Blue Spring Upgrade
jokester00 is offline
The Following User Says Thank You to jokester00 For This Useful Post:
post #5 of 13 Old 03-18-2017, 04:20 PM Thread Starter
Beerbait's Avatar
Quoted: 73 Post(s)
-jokester
Deltas are 6 to 8 so we are good there. I will flush it good and change it over.
Thanks guys for your help.
Beerbait
03 6.0 XLT
ex cab 4x4 Leather
Molon labe
Beerbait is offline
post #6 of 13 Old 03-18-2017, 04:34 PM
Sock Puppet's Avatar
Quoted: 150 Post(s)
I'm sure you've already read the other flush threads, but it's worth doing the Fumoto drain valve and a hose on the passenger side block drain. That way you only have to pull the starter once.
And...since you have to pull the starter, this is an excellent time to upgrade to the 6.4 starter.
2007 F-350 4X4 CCSB, 6.0 PSD, ZF6 Manual Trans, 3.73s, Blue Spring, High-Idle mod, Mishimoto coolant filter, 6.4 starter, Genex mirror, Magnum RT steps, Leer 100R Shell, custom front bumper replacement, 4" Cat Back exhaust, JVC head unit with backup camera, '08+ towing mirrors and rear diff. cover, etc.
Sock Puppet is offline
The Following User Says Thank You to Sock Puppet For This Useful Post:
Beerbait (03-19-2017)
post #7 of 13 Old 03-18-2017, 04:38 PM Thread Starter
Beerbait's Avatar
Quoted: 73 Post(s)
Is the 6.4 starter that much better? Faster? Expensive?
Beerbait
03 6.0 XLT
ex cab 4x4 Leather
Molon labe
Beerbait is offline
post #8 of 13 Old 03-18-2017, 05:39 PM
jokester00's Avatar
Quoted: 84 Post(s)
Garage
All 3
-jokester
djmaguire likes this.
SCT SF3 Tuner
Edge EAS EGT probe
Blue Spring Upgrade
post #9 of 13 Old 03-19-2017, 06:17 AM
Quoted: 150 Post(s)
Not too expensive. I bought one off of Fleabay advertised as having ~75K miles for $80 or so (don't really remember).
post #10 of 13 Old 03-19-2017, 08:19 AM
I've found the drain valves at TruckPro if you have one of those near you.
moparman_91 is offline
