Odometer accuracy
So, I know speedo is off by 10mph....do you think my odometer is off? I was next to my wife driving home in seperate cars and we clicked off a mile together. Once her Camry hit a mile my truck was at .09..... so I am guessing every 10 miles I go, I actually have gone 11.... so 100 miles I would have gone 110 and 200 is 220 and 300 is 330 and so on..... this must explain why I was thinking I should be getting more out of my 40 gallons then what the odometer was reading...thank god.... anybody have similar issues with thiers..
Yes it will be off. Mine is off, cant remember how bad though
mines off too. not sure how much. i have 315 tires (i think) and even with the sct rotations per mile thing, its still a little off
Everyone with over sized tirtes has this "issue". Mine was 7% off until I calibrated my odometer/speedometer with my AutoEnginuity scanner. Now it is dead on!
Before I knew I could do this I just compared my speed on the GPS with the speedometer and calculated the difference. Mine happened to be 7%. I would just add 7% to my miles logged before I divided by the gallons used. Now it is much better! |
PM sent. Call me tonight if you need to.
Here it is for everyone:
In the Ford module, when you pick your model and year, you can go to the bottom where you pick "generic" or "enhanced", etc., you pick "anti-lock brakes" or something like that. Then when the program starts, you go over to the tabs on the right side where you can run a buzz test, etc., for the Powerstrokes and there will now be a pull down for "Tire Selection" or something like that. Each click of the "<" or ">" on the screen with the mouse (not the ones on your keyboard) will change your tire diameter by 1/2". I run 315 BFG ATs which are not a full 35" high. I put in 34.5" and my speedo is dead on with my GPS! |
You da man Hank!
Now if I could just get it to connect to my wife's truck like it used too.... |
3.5% off with my 35's.
