oil and filters - Ford Powerstroke Diesel Forum
Old 11-22-2009, 05:02 PM
oil and filters
i use motorcraft everything but i wanted to know if anybody uses anything other than motorcraft how much sucess they have had and where online to get the oil and filters.
thanks
Old 11-22-2009, 05:13 PM
I use Napa Gold oil and fuel filters with Rotella 15w40.
Old 11-23-2009, 03:32 AM
Fram filters with Mobil 1 works great for me.
Old 11-23-2009, 03:42 AM
Do an oil search and you will find tons of info! Motorcraft oil filter (Walmart or Ford) and Mobil 1 Turbo Diesel Truck 5w40, premium oil for these motors....(walmart or autozone)
Old 11-23-2009, 05:42 AM
Motocraft filter with rotellat oil has always worked the best for me and all my buddies...
Old 11-23-2009, 08:54 AM
I deal and use only WIX filters. I recently switched from Rotella to Brad Penn diesel oil (it is highly regarded oil in the racing field and shows good numbers in UOA's). I will use only WIX filters on my racecar, pickup and my Raptor. Have seen bad things happen with Fram filters since I've been at this shop...
Old 11-23-2009, 09:07 AM
Shaking the Bush Boss
Rotella 15w40 and Wix or motorcraft filters. I got a good deal on a case of Wix filters....only reason I swapped....I'll go back to the motorcraft when I'm out of the Wix
Old 11-23-2009, 09:31 AM
Stick with the Racor (Moorcraft) filters. You cant go wrong with them. Excellent filtration and cheap pricing.
6.0l Filters
