Insight question? - Ford Powerstroke Diesel Forum
post #1 of 9 Old 11-22-2009, 11:59 AM Thread Starter
93calypsohatch's Avatar
Insight question?
Just installed my insight with EGT probe but the screen reads EGT N/A. What did I do wrong?
93calypsohatch is offline
post #2 of 9 Old 11-22-2009, 12:41 PM
tmullins214's Avatar
There are two egts. Try the one under the Temperature (the first tree). There is also one under Ford then under Air. I almost positive you need to use the one under Temperature.
Timmy
'08 Job 1 F-250 CCLB Lariat Audiophile DVD
Airaid, Mini Max, Performance Machine & Manufacturing Egr Delete Intake & IC Pipe, 4" Turbo Back MBRP, Recon everything, Icon 2.5" springs, PMF 2" traction blocks, 37X12.50X20 Nitto Trail Grappler, Body color headlights grille & handles
tmullins214 is offline
post #3 of 9 Old 11-22-2009, 12:56 PM
I don't know if this will look right, but these are all the insight gauges that work on my truck with the optional egt probe.
Edge Insight Gauges
Temp Coolant Temp
Intake Air Temp
Exhaust Gas Temp
Fuel Fuel Flow
Fuel Economy
Air Intake Manifold Pressure (kPa)
Mass Air Flow Sensor
Spark/L Engine Load
T/D/C Trouble Codes
Sensors
RPM
Vehicle Speed
Ford Fuel Injector PW
Air MAPg
Sensors Diesel Eng. Oil Temp
Transmission Temp
Trans Input Shaft Spd
Trans Output Shaft Spd
TCC Speed Ratio
Torque Converter Slip
Turbine Speed
Intake Air Temp #2
Timmy
post #4 of 9 Old 11-23-2009, 06:40 AM
Abrannan19's Avatar
Feedback Score: 5 reviews
if you have the setup on say the quad display and EGT is one of the 4 parameters you are monitoring and the pyro isnt plugged in, you need to set the EGT to something different (anything but EGT) turn the truck on, then after you have done this, you can switch back to EGT and it should read just fine.
Adam Brannan
First Coast Diesel Performance
Abrannan19 is offline
post #5 of 9 Old 11-23-2009, 01:50 PM Thread Starter
That fixed it. Thanks!
post #6 of 9 Old 11-23-2009, 06:48 PM
MoyockPowerstroke's Avatar
Good to know, waiting on my probe any day now.
'05 6.0L, 128k miles, Racor CCV6000 Filter, Oil Bypass Filter, Fumoto drain valves, Coolant Filter, ZooDad, HighIdleMod, BullyDog 4" TB, VXCF9 Strat, Edge Insight Gauge, Torque App, Fuel Press Gauge, Upfitters, 4" SJ lift w/Bilstein 5100's, Ride-Rite Airbags, Rough Country Dual Stabilizers, 24" Wipers, '08 Rear Diff cover, Mobil1 Syn 5W-40, 6.4L banjos, Blue Fuel Spring, SS HPOP screen, '08 Mirrors, Zerex ELC.
MoyockPowerstroke is offline
post #7 of 9 Old 11-23-2009, 06:51 PM
Also, don't mean to hi-jack, but can those who use the Insight tell me what you see for Mod Volts? I see between 11.2v -12.2v at initial start up for as long as 56 seconds, then between 13.5v -13.7v during normal driving thereafter. Are these normal readings...can you help me compare?
post #8 of 9 Old 11-23-2009, 07:21 PM
Abrannan19's Avatar
those volts are about normal IMHO, as soon as I start my truck they volts are around 11ish, by the time I am rolling is 13.5
Adam Brannan
post #9 of 9 Old 11-23-2009, 07:22 PM
Abrannan19's Avatar
Awesome! Good to hear and happy to help!
Adam Brannan
