3-4 sec cranking time? What could this be? - Ford Powerstroke Diesel Forum
post #1 of 11 Old 11-19-2009, 04:32 AM Thread Starter
MoyockPowerstroke's Avatar
I used to get in and she started right up...maybe one or two cycles...now its more like 3-4 cycles...what could this be?
'05 6.0L, 128k miles, Racor CCV6000 Filter, Oil Bypass Filter, Fumoto drain valves, Coolant Filter, ZooDad, HighIdleMod, BullyDog 4" TB, VXCF9 Strat, Edge Insight Gauge, Torque App, Fuel Press Gauge, Upfitters, 4" SJ lift w/Bilstein 5100's, Ride-Rite Airbags, Rough Country Dual Stabilizers, 24" Wipers, '08 Rear Diff cover, Mobil1 Syn 5W-40, 6.4L banjos, Blue Fuel Spring, SS HPOP screen, '08 Mirrors, Zerex ELC.
MoyockPowerstroke is offline
post #2 of 11 Old 11-19-2009, 07:06 AM
Once I get to an end of a oil change interval ( last 1k miles ) my truck takes a little longer to start. Since I have switched over from Amsoil 15-40 full synthetic to Schaeffers 5-40 full synthetic, I have not had this happen. I change my oil every 5k miles no matter what. If this does not fix your problem It could be a multiple of things. Like stc fitting, oil rail plugs leaking, Ficm. People seam to like the new flash Ford just came out with.
Big Mule is offline
post #3 of 11 Old 11-19-2009, 09:12 AM
Chapter Director
psd_va's Avatar
i have the same problem and was told icp sensor so i replaced it with no change
03 F350 6.0 SRW 4X4 lariat
481hp 832tq
8" super lift 385/70r16 Toyo MT's
FatBoy traction bars
Durastroke stg1
intake
MBRP 5" straight pipe
Custom tuned by Vivian "Looney Wild Track"
Edge Insight CTS
Zoodad mod
high idle mod
6.4 banjo bolts
Updated fuel pressure regulator (Blue spring mod)
EGR cooler delete
6K 55w HID's
6k 35w fog HID's
B&W turnover ball
psd_va is offline
post #4 of 11 Old 11-19-2009, 09:20 AM
Baddestt's Avatar
Quoted: 8 Post(s)
If your running that thick heavy 15w40 dino oil in this cold winter then its gonna take a few seconds to fire up. If you want to run a 15w40, I recommend the synthetic version, such as Amsoil AME or the synthetic blend from Valvoline Premium Blue. Otherwise, run a 5w40 synthetic such as Mobil 1 Turbo Diesel Truck or Valvoline Premium Blue Extreme. Much easier and quicker cold starts. Make sure your running a good diesel fuel lubricant too with cetane boost. Ford has some good stuff you can get at the parts section. I run the Mobil 1 TDT and 2 stroke TCW-3 ashless oil in the diesel and it fires up almost as quick as I turn the key
'07 F-250 PSD 4x4
5" exhaust, zoodad, blue spring, Airaid intake, 6.4 starter, 2.5 f/coils, adj Trac bar, 2" r/add-a-leafs, egr delete, snow plow fan clutch, csf 6028 intercoolerr, DC 185 alt, Bilstein 5100, Barder '03 turbo rebuild w/RR billet wheel, SCT SF3 tuner, F-Detroit Truetrac, R-Detroit Locker, 4:10 gears, hawk LTS, LT315/70r17 Duratracs, Amsoil Gear lube, Delo 400 LE 5w30 diesel, Delo ELC, archoil, bpd ficm, BPD oil cooler, dynatrac pro steer ball joints, arp studs, oem gaskets, HD water pump, stc, plugs, stand pipes, 6.4 banjo bolts,
Baddestt is offline
post #5 of 11 Old 11-19-2009, 09:26 AM
Slated4greatness's Avatar
Quoted: 3 Post(s)
It could also be injectors. I've had mine in twice for this and both times they changed 2 injectors (4 different ones).
2006 Dark Slate F350 CC LB 6X6 Lariat Tow Boss edition, Complete with training wheels.
BPD VK688 Kit, W Pump, EGR, FICM, Decked block & Heads, ARP's, Coolant filter, RR, Aux coolant lines, Train Horns, SCT W/GH tunes, Recon smoked LEDs, Pressure pro TPMS, Firestone air bags, Alpine/Infinity/Polk sound system, CTS Monitor and Autometer analog backups. MPG Max Water injection with custom 17 gallon tank. 4" straight to 6" Aussies.
Slated4greatness is offline
post #6 of 11 Old 11-19-2009, 10:32 AM
Chapter Director
psd_va's Avatar
yea i had a feeling that oil could cause it i am switching to premium blue 5w40 next oil change i jsut have to find it first too. and i hope its not an injector but i have a feeling it is cause it kinda stumbles at first start up if cold enough
481hp 832tq
Durastroke stg1
intake
Edge Insight CTS
Zoodad mod
high idle mod
6.4 banjo bolts
EGR cooler delete
6K 55w HID's
6k 35w fog HID's
B&W turnover ball
psd_va is offline
post #7 of 11 Old 11-19-2009, 11:35 AM
Baddestt's Avatar
Quoted: 8 Post(s)
FYI
Valvoline Premium Blue EXTREME 5w40 can be obtained from NAPA... expect to pay anywhere from $17.99-$26 a gallon
Mobil 1 Turbo Diesel Truck 5w40- Walmart $21 a gallon or Autozone $6.99 a quart...
I hope its not the injectors too bud, that would suck
'07 F-250 PSD 4x4
Baddestt is offline
post #8 of 11 Old 11-19-2009, 04:32 PM
Powerstroke Techie
Glow Plugs
Oil Rail Plug
STC
All possibilities
5 Year Ford Certified Diesel Master Technician
Specializing in: 6.0, 6.4, 6.7, and 7.3 Powerstroke Diesel
Currently Employed as a Diesel Technician for the
Walt Disney World Resort in Orlando, FL.
Specializing in: Detroit/Cummins/International
DieselDano is offline
post #9 of 11 Old 11-19-2009, 04:40 PM
Mine was the same way till I replaced two injectors and now she fires right up.
redsmoke is offline
post #10 of 11 Old 11-19-2009, 04:53 PM Thread Starter
In my sig, you'll see that I run Mobil1 5w40, (have since I started doing my own changes), also run a Amsoil bypass, I also use Stanadyne each fill up, getting ready to start using FBBP...I ran the scan tool, nothing shows up...so I don't expect it to be anything serious...keeping fingers crossed.
