It's 50/50 I can't find consontrate anywhere in pc. I did the flush today with 24 gallons of distilled water and 50/50 peak. Ordering some concentrate online and will drain some and add concentrate later this week to help balance it out.
Got this on today though. No leaks . I added teflon tape and used clamps from tractor supply that were the proper fitting then the crap sinister sent. They really went cheap on the clamps.
Thanks for "heads up"! I have a very small coolant leak that as of today I still cannot find!! Gonna send in my MISHI version 1 soon so I'll be needing some coolant for that swap as well.
Yeah I saw that a couple days ago. They only had two bottles k even went in the back to ask lol. can elc coolants be mixed? I have ordered my concentrate though. Should be here Friday or Monday next week. Damn $30 a gallon.
For the time being I filled with 2.5 gallons 50/50. Drove 45 min with heat on high repeat. I did that 4 times. Then once my concentrate gets in I will drain a gallon add a gallon of concentrate drive for a few days and then drain and add another gallon of concentrate. Then I should be good to go.
Sounds like a plan. As far as I know you can mix the higher grade EC-1 rated coolants, but I don't think I would. Not worth the chance of a bad chemical reaction causing sludge or something, IMO. If you used 50/50 Final Charge, I'd probably stick with the Final Charge concentrate for the drain and fill swaps.
Related Threads
Ford Powerstroke Diesel Forum
5.4M posts
265.8K members
Since 2005
