coolant filter question - Ford Powerstroke Diesel Forum
Old 11-18-2009, 05:30 AM
Why use the high side hose and dump into the degas bottle hose. Why not just install it inline with one of the heater core lines?
Old 11-18-2009, 05:58 AM
The reasoning is to have it as a bypass, so when it plugs up with debris it is not clogging your main hoses.
Old 11-18-2009, 08:15 AM
I need a bracket than to mount my coolant filter setup in the front of the engine bay, anybody have one?
Old 11-18-2009, 09:10 AM
Just get on a vendor website and have a look at the one with their kit, it would be easy to fab one up
Old 11-18-2009, 09:18 AM
Slacker
Feedback Score: 4 reviews
Dieselsite's kit is probably the most common.
Old 11-18-2009, 05:21 PM
How bout a piece o' angle iron off the alternator ? Good for oil by-pass filter too !
Old 11-23-2009, 08:29 AM
I'm in the process of making a bracket, not a big deal. So which hose do I T off offor the input? The two directions I've read off the internet are vague. Is it the hose that has a fitting for what I assume is pressure testing?
Old 12-15-2009, 06:28 PM
Some more info on your filtration would be awesome
Old 12-15-2009, 06:33 PM
for us guys with 94-95 powerstrokes, our only option is pretty much using them with the heater hoses, however instead of being inline, you put them between the hot and cold side, the resistance from the filter should still alow hot fluid to go to your heater core while only a little bit will pass through the filter and cycle back towards block, its what all the idi guys are doing since they didnt put a degas bottle till late 95-96
