im upgrading my rearend cover, which fluid for stock 160k mile rear end??? - Ford Powerstroke Diesel Forum
 5Likes
post #1 of 25 Old 02-17-2017, 06:14 AM Thread Starter
Quoted: 9 Post(s)
My rear end is starting to make some noise when turning tight corners after its heated up. It hasn't been serviced in 80k miles, so I'd like to upgrade the rear end cover as well. Is the Magtec still the best one out there and which fluid should i use for the stock 160k mile rear end. Should I go to 75w-140 Amsoil and how much friction modifier due i use in the bigger cover?
2005 Dark Blue F-250 Harley Davidson 4x4. SCT Livewire TS, 4" Silverline TBE, Sinister intake elbow, Riff Raff turbo boots, Blue spring, 6.4 banjo bolts, Sinister coolant filter, Fleetguard OAT, IPR EGR delete, ARP studs.
1998 Dodge Viper GTS. Silver/Blue stripes 1 of 21: Corsa exhaust, high flow cats, K&N filters, smooth tubes
Invasivore is offline
post #2 of 25 Old 02-17-2017, 06:58 AM
Sock Puppet's Avatar
Quoted: 137 Post(s)
Most 75W140 Synthetics have friction modifier in it so you won't need to add any extra. I used Valvoline last year and have no complaints.
Ford went to an upgraded aluminum cover with fins in 2008. I think mine was around $75 and works just fine. You'll also need to upgrade your hardware as the aluminum cover is thicker.
2007 F-350 4X4 CCSB, 6.0 PSD, ZF6 Manual Trans, 3.73s, Blue Spring, High-Idle mod, Mishimoto coolant filter, 6.4 starter, Genex mirror, Magnum RT steps, Leer 100R Shell, custom front bumper replacement, 4" Cat Back exhaust, JVC head unit with backup camera, '08+ towing mirrors and rear diff. cover, etc.
Sock Puppet is offline
post #3 of 25 Old 02-17-2017, 07:01 AM
Quoted: 137 Post(s)
Found a pic of the upgraded Ford cover that I installed:
post #4 of 25 Old 02-17-2017, 07:16 AM
Heavy_GD's Avatar
Quoted: 1436 Post(s)
Feedback Score: 3 reviews
All Amsoil all the time.
jd4010 and kcoyner like this.
GD
Originally Posted by 6.0Stroker View Post
It's Toren. .. don't question it ..
Heavy_GD is offline
post #5 of 25 Old 02-17-2017, 07:22 AM
JustinOOO9's Avatar
Quoted: 471 Post(s)
Garage
I used valvoline 75w-140 full synthetic. Found it at Napa for like $9 a quart. My rear end had 120k on it from the original owner before it was changed. Like others said probably 99% of the synthetics have the friction modifier already in it.
If you do the 2008 rear dif cover you need new nuts n bolts too. It's a different method then the oem 1999-2007 rear ends cover etc.
Some company's sell a kit that's a bit overpriced but... saves you all the research hassle and trying to find the hardware at a local store etc.
WD40 likes this.
JustinOOO9 is offline
post #6 of 25 Old 02-17-2017, 07:41 AM
Durapig Eater's Avatar
Quoted: 82 Post(s)
It will say if it has the limited slip additive in it or not. I used Lucas last time, not sure if the Valvoline is FULL synthetic or not, Amsoil, Mobile 1, Motorcraft would be.
The additive is to stop chatter, but technically it reduces the effectiveness of the LSD (makes the clutches slip some) so I would probably just fill with a good full synthetic and see if'n she chatters. If so pull out a little fluid and put in a bottle of the Motorcraft LSD additive (4oz)
Personal Truck/Heavy Hauler 12 F350 XL 4x4 DRW CCLB 3.73 LSD Black
Shop built headache rack, tie downs, and knock down ladder rack, Tread plate bed mat, X3 5* tow tune, Cheapo light bar, bug screen on the grill, shimmed overloads, CTS
The Mother Ship 03 Ex 2wd Limited V10 4.10 LSD Mineral Grey Metalic (champagne)
170k and counting hauls kids here, there, and everywhere
The "work truck" 02 Honda Odyssey ELX 165k
Just because your not paranoid doesn't mean their not out to get you...
Durapig Eater is offline
post #7 of 25 Old 02-17-2017, 10:20 AM
portcity_gt's Avatar
Quoted: 1272 Post(s)
Just put a trutrac in it while you're in there, that way you can save money by not having to use any friction modifier
03 cclb dually,6.0,arp studs,bpd oil cooler,bpd 6 phase ficm,bpd water pump,bpd all aluminum cac,all aluminum radiator,amsoil bypass oil filter,ipr high flow coolant filter,egr delete,livewire ts tuned by Vivian & tony,php ficm tuner,dc power 300-spx,Detroit trutrac,6" dual side pipes,07 front end,custom front bumper,shaved badges,led button roof lights,08+ mirrors,12 tailgate,13 rear bumper,13 tail lights,dropped I beams,custom rear 4 link w/bags,k5la train horn,24" alcoa's.
portcity_gt is offline
post #8 of 25 Old 02-17-2017, 10:40 AM
Quoted: 98 Post(s)
When I changed my rear diff oil, I never found a need to use any friction modifier. Always used Amsoil Severe Gear and still have a new tube of their Slip Lock additive untouched. So my suggestion....don't add any until you know it is needed.
2004 F350 6.0 - Traded 2/4/17
2017 F350 DRW King Ranch - On Order
jd4010 is offline
post #9 of 25 Old 02-17-2017, 12:47 PM
JustinOOO9's Avatar
Quoted: 471 Post(s)
Garage
I purchased the valvoline full synthetic. It stated it had the lsd additive and no chatter so far.
I have yet to see a full synthetic that doesn't have an addative. Also Autozone and o Riley is a total rip off in my area. Napa and Walmart sold the same stuff for way way cheaper.
post #10 of 25 Old 02-17-2017, 05:55 PM Thread Starter
Quoted: 9 Post(s)
Well i decided to go with the Mag-hytec 6 quart cover with Schaeffer's performance 75w-140 synthetic. I'm actually looking forward to see how the fluid does since they make excellent motor oil.
Have any of you hooked a temp sender to the housing that works with the SCT livewire programmer?
