lift ??? - Ford Powerstroke Diesel Forum
Old 03-17-2007, 04:38 PM
im fat and ugly
lift ???
how high do i have to start changing things in the front, as far as the pitman arm and stuff?
right now i have 2" shackles installed in the front, and plann on adding some 2.5" springs soon, thatll give me 4.5 in the front, will i be safe without anything else besides shocks?
Old 03-17-2007, 04:45 PM
I have a 4.5 DR hanger kit and needed a drop pitman arm and a trac bar drop bracket.
I think you will need the same or you will have some steering issues (if it even bolts up at all)
Old 03-17-2007, 05:30 PM
im fat and ugly
what kind of steering issues would i have?
Old 03-17-2007, 05:51 PM
I think that anything over 3 inches and you need a drop pitman arm, if not then everything will not bolt up.
Old 03-17-2007, 05:54 PM
Power Strokeaholic
i think skyjacker recommends a drop pitman arm for anything over 4". don't quote me thou.
Old 03-17-2007, 09:19 PM
You should get a dropped pitman arm and a trac bar drop down bracket. The steering issues you will face will most certainly be bump steer, which is not fun believe me. You could also get a crossover steering and not have to get a dropped pitman arm but that is way more expensive.
Old 03-18-2007, 07:37 AM
im fat and ugly
what exactly is bump steer, when you hit a bump and teh wheel goes where it pleases?
Old 03-18-2007, 12:24 PM
International Threat
Originally Posted by stump0331 View Post
what exactly is bump steer?
Bump Steer
Hope this helps!
Old 03-18-2007, 12:47 PM
im fat and ugly
that sums it up thanks marty
