Engine Light On - Ford Powerstroke Diesel Forum
post #1 of 15 Old 11-14-2009, 12:48 PM Thread Starter
topdwg's Avatar
Engine Light On
So I was driving to PetSmart and my dang engine light came on. So when I got to PetSmart I pulled out my SCT and found the code P2262. So I did a little reading and to make a long story short I found my MAP sensor hose had a huge crack down it. The crack didn't just happen over night, so I wonder why today it decided to throw a cell? Also what does this hose do? With by fixing it what actually gets fixed? I know MAP stands for Manifold Absolute Pressure, but what is it measuring?
Thanks
2012 F-350 SRW King Ranch
SOLD - 2004 Lariat F-250 4x4
6.5 Pro Comp Lift W/ Fox Shocks, DeeZee Tool Box, 08 Diff. Cover, 37x13.5/20's Pro Comps, Zoodad Mod, SCT w/custom tunes, 4 in EX., AFE Intake, ARP, Recon Lights, High Idle Mod, RCD EGR Delete, Fumoto Valve, Oil Bypass Kit, 03 Turbo, Yukon Gears, Farmboy Stage II Traction Bars, Dieselsite Coolant Kit, Amsoil, HIDS, Edge Insight CS, PHP FICM
topdwg is offline
post #2 of 15 Old 11-14-2009, 02:09 PM Thread Starter
topdwg's Avatar
No one knows what a MAP sensor does?
topdwg is offline
post #3 of 15 Old 11-15-2009, 03:25 AM Thread Starter
topdwg's Avatar
Here's the crack. Notice it was right at the base.
topdwg is offline
post #4 of 15 Old 11-15-2009, 10:28 AM Thread Starter
topdwg's Avatar
Going once, going twice, anyone???
topdwg is offline
post #5 of 15 Old 11-15-2009, 10:56 AM
Don't mind me
westcoaststrokin's Avatar
Quoted: 3 Post(s)
I don't know what the MAP sensor does but I know that is where I Teed in my boost gauge.
Josh
04 F350 CC SB DRW IT HAS SOME STUFF
"Idiopathic, from the Latin meaning we're idiots cause we can't figure out what's causing it." House M.D.
westcoaststrokin is offline
post #6 of 15 Old 11-15-2009, 10:59 AM
Quoted: 8 Post(s)
The MAP sensor is a variable capacitor sensor that is supplied a 5-volt reference signal by the PCM and returns a voltage signal to the PCM relative to the intake manifold pressure. The sensor voltage increases as the pressure increases. The MAP sensor allows the PCM to determine the engine boost to calculate fuel quantity. In addition, the MAP signal is used to control smoke by limiting fuel quantity during acceleration until a specified boost pressure is obtained, and is used by the PCM for EGR system calculations and control. A MAP signal fault detected by the PCM causes the PCM to calculate an estimated manifold pressure based on known engine conditions.
Mark
06 F250CC SB FX4 Lariat;ARP studs;OEM gaskets; Banks exhaust;DynaTrac Ball joints;Coolant filter; High-Idle;RACCCV6000;JimmiJammers;Ravelco;SynchroMax trans case;Fumoto valves;Harpooned;CPOhighwayProducts toolbox;tracrac;Fox Weatherboots;Wet Okole Seat Covers;BriteBox;Re-flashed;Quadzilla Recon XZT Fuel Press;Blue FPR spring;DashDAQ;PHP FICM;RiffRaff boots;DCPower270AXP;PowerInverter;Rancho7000's; BPD EGR cooler;One-piece HPOP fitting;BilletWaterPump;SCT w/ Matts SRL;ELC Ultra
bismic is offline
post #7 of 15 Old 11-15-2009, 11:15 AM
Quoted: 5 Post(s)
yep that about sums it up
Originally Posted by Ianstew
There is a difference in a government acting responsibly within their powers, and a government that just decides what their powers are and what responsibility means based on political whimsy.
ianstew is offline
post #8 of 15 Old 11-15-2009, 11:53 AM
Tacomarunner's Avatar
Doesn't look like sensor is bad, just a cracked hose. Easy fix.
O7 F-5504dr 4wd cab and chasis w/ 12' Scelzi service body 6spd manual trans. 200" WB 17,950 GWWR 4.88 gears
Overhead gauges w/ EGT and Boost. FCDP EGR Delete. AEM Workhorse CAI. Down pipe only, no cat or muff.
Tacomarunner is offline
post #9 of 15 Old 11-15-2009, 12:47 PM Thread Starter
topdwg's Avatar
Awesome, thanks! Could this be the reason why the code P2262 was thrown?
topdwg is offline
post #10 of 15 Old 11-15-2009, 02:36 PM Thread Starter
topdwg's Avatar
Hey by fixing this do you think my mpg will go up? I know after just going down the road it seemed to run a little better. Seemed to spoil up a little smoother.
topdwg is offline
