What could have happen?? PICS..... - Ford Powerstroke Diesel Forum
post #1 of 12 Old 11-14-2009, 09:11 AM Thread Starter
psi_2_high's Avatar
looks like im leaking coolant or something ..... the cap is on tight and the plastic has no cracks or anything of that sort ...... and my truck is and has been running great........ any suggestions thanks alot guys!!!
2011 F350 FX4, Lariat, Recon Lights, more to come!!
2005 F250 ,Garret PowerMaxx, Studded, Bulletproof EGR Delete, 12" Rize quad link / King Coils / King Ress shocks, 4.56 Gears, Full HD interior, Straight Piped, Toyo 40/15.50/22 Fuel Hostage Deep Rim. And a ton more stuff i forgot!!
psi_2_high is offline
post #2 of 12 Old 11-14-2009, 09:15 AM
Probably have a blown head gasket or egr problems..
2005 f250 lariat FX4 crew cab short bed
4" ss mbrp, muffler and kitty gone.. Arp studs, and egr delete
SCT tuned by eric..
08 mirrors
More mods to come..
190 casserly injectors
stage 2 vgt
fuel system, airdog2
shot of nitrous?
kenny7231 is offline
post #3 of 12 Old 11-14-2009, 09:30 AM
Mine is at the dealrship right now for the exact same thing. The coolant will get down to a level about 2 inches below the MIN. line and stay there and not puke. If I fill it up to the MIN line it will puke down to that point. I had it checked out at a shop before it went to the dealer because I know the dealer will sit on it for a week before looking at it. 2 possible problems: 1. EGR cooler 2. headgaskets. My cooler checked out OK, so it must be headgaskets leaking (not bad, but will only get worse). I'll let you know what the dealer says when they do their diagnosis.
2013 F250 CC/SWB Lariat FX4
325/60/20 Nitto Terra Grapplers
NOBAMA!!
Is it just me, or does it seem like all Dodge drivers are A$$holes?
jdalhaus is offline
post #4 of 12 Old 11-14-2009, 09:34 AM Thread Starter
psi_2_high's Avatar
yes please let me no ....... the dealer just put in a new EGR about a month ago......
post #5 of 12 Old 11-14-2009, 09:34 AM
It could be that you just had too much coolant and it puked a little. The reservoir is only supposed to be full to the minimum line. I also added an 08 cap to stop it from puking.
03-blue-Powerstroke is offline
post #6 of 12 Old 11-14-2009, 09:36 AM
smokersteve's Avatar
Quoted: 20 Post(s)
that sucks. hed gaskets, egr...
13Q Trans Fluid Flush
FICM Testing Videos
smokersteve is offline
post #7 of 12 Old 11-14-2009, 09:39 AM
Think positive
post #8 of 12 Old 11-14-2009, 02:05 PM
make sure the surface of the resvoir is flat . test the cap to make sure it is holding pressure . those are 2 parts of the egr cooler tsb . I have found a lot of times when the cooler goes it heats the overflow tank to the point of warpage . i replace thoses under waranty when i do them
sportsman500 is offline
post #9 of 12 Old 11-14-2009, 02:18 PM Thread Starter
psi_2_high's Avatar
yea the truck is on its way into the dealer........ will post info
post #10 of 12 Old 11-16-2009, 03:47 PM Thread Starter
psi_2_high's Avatar
well i got the truck back today and it turns out it was the cap ....... it was only holding 2 psi and they put on a new cap that should hold about 20 psi........
