it is deleted and the valve is stil there?
i guess i am ignorant of what an EGR delete consists of ...hhhmmm
mine is a sinister brand delete kit...looks like a flat blue anodized plate bolted down on the intake manifold. so i am reasonably sure there is no valve on mine...and i found the empty plug where the EGR would have been attached
Depends on the strategy. Seems the earlier trucks don't have much of an issue, at least not throwing a CEL. They may set a soft code for Insufficient flow though. Others don't seem to even notice it's gone. For safety's sake on mine, I leave it plugged in since there is also the possibility of affecting cooling fan function. I've got a BPD cooler with a spool plug in the EGR hole and the valve bolted beside it.
Depends on the strategy. Seems the earlier trucks don't have much of an issue, at least not throwing a CEL. They may set a soft code for I n sufficient flow though. Others don't seem to even notice it's gone. For safety's sake on mine, I leave it plugged in since there is also the possibility of affecting cooling fan function. I've got a BPD cooler with a spool plug in the EGR hole and the valve bolted beside it.
I throw a soft code if it's not plugged in. But now that I think about it I have the 7.3 manual fan clutch so I don't even need to to have the valve plugged in anymore...lol
"We cannot solve our problems with the same thinking we used when we created them."
I guess I'm a little concerned with that. I bought this truck 2 months ago, EGR delete, studded, blah blah blah
I've got no P-codes in memory, which I guess means I've got a tune.... but no tuner.
Does that mean I have no stock file to go back to, should I buy a tuner?
I should say that my EGR is turned off with tuning and I've never received a code for it. I put the spool in as extra insurance in case the valve ever stuck or blew open under boost.
Yes, p0401 can be caused by anything that causes less of a drop in maf and ebp when the egr valve is commanded open. That is what the PCM monitors when determining egr flow
Related Threads
Ford Powerstroke Diesel Forum
5.4M posts
265.8K members
Since 2005
