Oasis please
Well I think I have finally found a truck that I am interested in so could one of you kind ford folks run the oasis on it please?
The VIN is 1FTSW21P35EA28836 It is an '05 with 130k on it so it should be good for a few more miles for me. Thanks in adavance. |
i wanna know how to do the oasis also
Here is a bump for you, but i don't think they are running them anymore on here. I guess Ford tightened up on letting 3rd parties run oasis reports. maybe something has changed, but i don't think so.
VIN VEH LINE MKT DERIV BODY CAB VER SERIES DRIVE TYPE PLT CD TRS CD ENG CD PROD DATE WARR DATE SELLING DEALER SELL CNT TIS WCC CPSC_6 PREF BASE SUFF CCC CD DIST(Miles)
1FTSW21P35EA28836 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 08-AUG-2004 24-OCT-2005 123359 USA 0 6N04 010802 5C3Z 16720 EB B66 D4 11 AWS Claim Key: 121585 Trx Code: 1 Labor Hrs: 0.1 Dlr Cd-Sub Cd: 04357 - * Name: DOBBS FORD LINCOLN MERCURY AT WOLFCHASE Ph: 901-3825555 St:TN Ctry Cd: USA Reg Cd: NA Repr Date:20-OCT-2004 Doc #:06044201 Cust Comments: PAINT PEELING OFF OF TWO EMBLEMS Tech Comments: REPLACED EMBLEMS -------------------------------------------------------------------------------- 1FTSW21P35EA28836 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 08-AUG-2004 24-OCT-2005 123359 USA 0 1H02 120307 4C3Z 2A451 BA C05 42 20 AWS Claim Key: 930749 Trx Code: 1 Labor Hrs: 0.3 Dlr Cd-Sub Cd: 04357 - * Name: DOBBS FORD LINCOLN MERCURY AT WOLFCHASE Ph: 901-3825555 St:TN Ctry Cd: USA Reg Cd: NA Repr Date:20-MAY-2005 Doc #:07481901 Cust Comments: C S AC FAN NOT BLOWING Tech Comments: 1 REPLACE VAC PUMP . -------------------------------------------------------------------------------- 1FTSW21P35EA28836 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 08-AUG-2004 24-OCT-2005 123359 USA 17 * * * * * * * 88297 AWS Claim Key: 7266870 Trx Code: 05E15 Labor Hrs: 1 Dlr Cd-Sub Cd: 06578 - * Name: COURTESY MOTORS, INC. Ph: 601-5448111 St:MS Ctry Cd: USA Reg Cd: NA Repr Date:22-FEB-2007 Doc #:114326B Cust Comments: RECALL 05E15 Tech Comments: 88297 RECALL 05E15 W PERFORMED RECALL 05E15 REPLACED EBP SENSOR REPROGRAMMED MODULES -------------------------------------------------------------------------------- 1FTSW21P35EA28836 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 08-AUG-2004 24-OCT-2005 123359 USA 17 * * * * * * * 88297 AWS Claim Key: 7266872 Trx Code: 05B32 Labor Hrs: 0.2 Dlr Cd-Sub Cd: 06578 - * Name: COURTESY MOTORS, INC. Ph: 601-5448111 St:MS Ctry Cd: USA Reg Cd: NA Repr Date:22-FEB-2007 Doc #:114326D Cust Comments: RECALL 05B32 Tech Comments: 88297 RECALL 05B32 W PERFORMED RECALL 05B32 INSTALLED DE GAS BOTTLE LABEL ASY -------------------------------------------------------------------------------- 1FTSW21P35EA28836 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 08-AUG-2004 24-OCT-2005 123359 USA 17 2E06 0304XX 5C4Z 9A543 B D02 42 88297 AWS Claim Key: 7266869 Trx Code: E72 Labor Hrs: 7.5 Dlr Cd-Sub Cd: 06578 - * Name: COURTESY MOTORS, INC. Ph: 601-5448111 St:MS Ctry Cd: USA Reg Cd: NA Repr Date:22-FEB-2007 Doc #:114326A Cust Comments: CUSTOMER STATES WILL NOT CRANK Tech Comments: 88297 W95 RAN EEC TEST. KOEO, CONT. INJECTOR BUZZ. CODE P2291, ICP LOW. RAN PINPOINT TEST AQ1, AQ2 AQ3, AQ4, FOUND IPR STUCK OPEN. REMOVED HIGH PRESSURE PUMP AND FOUND PART OF IPR IN PUMP. REPLACED THE HIGH PRESSURE PUMP, IPR, AND INSTALLED STC KIT AT BRANCH TUBE. INSTALLED ALL BACK. CONCERN CORRECTED. TEST DROVE AND CLEARED CODE. RERAN EEC TESTS. NO CODES AFTER REPAIR. -------------------------------------------------------------------------------- 1FTSW21P35EA28836 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 08-AUG-2004 24-OCT-2005 123359 USA 17 * * * * * * * 88297 AWS Claim Key: 7266871 Trx Code: 59B01 Labor Hrs: 0.3 Dlr Cd-Sub Cd: 06578 - * Name: COURTESY MOTORS, INC. Ph: 601-5448111 St:MS Ctry Cd: USA Reg Cd: NA Repr Date:22-FEB-2007 Doc #:114326C Cust Comments: RECALL 59B01 Tech Comments: 88297 RECALL 59B01 W PERFORMED RECALL 59B01 TEST DRIVE -------------------------------------------------------------------------------- |
Are you able to run an oasis report? I'm fixing to buy a truck but would like to get the report on it before? thanks |
Can someone please get me an oasis report on an '05 F-350 1FTWW31P75EA18771 ASAP thanks!
Oasis reports are reserved for premium members. There is a place to post them here: Oasis Requests
well thanks a lot for the help
Just upgraded my membership to run one! $20.00 well spent
