Transmission line/cooler leak help
On my 2006 F350 one of the transmission lines into the radiator on the passenger side is leaking right at the hose/fitting joint. Does anyone know where I can buy that hose or how to fix that piece? Also when I disconnect it from the radiator how much ATF fluid will come out? Thanks for the advice to a newbie!!
Mine is connected with hoseclamps. Is your connection a compression fitting on the hose. Oh and depending on how long it is disconnected. I loose about 1-2 quarts. After you get it hooked all back up. Park on level ground start the truck up and check the trans fluid.
it does have compression fittings. In ordrer to replace it do I have to replace the entire hose?
If it is leaking at the compression fitting. Are you sure that is where it is leaking at.
