Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > General 6.0L Discussion
Old 11-08-2009, 07:43 AM
pshea2 pshea2 is offline
After EGR Delete, and MBRP 4" T/B Install.
Hello all,
Im sure these questions have been mentioned before, but I figured I would ask and get some fresh new answers.
I just finished an EGR cooler delete, I removed the restriction in the up pipe and had the cooler capped on both ends, than I pressure tested it and it don't leak so I put the cooler back in in order to keep the coolant flow. It is a 2006 f-350, K&N FIPK intake,4" MBRP T/B cat delete and no programmer. My question's are,
1. Is it normal to lose Boost after this ?. I noticed coming in the road the other day before I did this I was getting 29 PSI, Now I get 22 PSI Max, Is this because there is less restriction now?
2. I never disconnected the plug to the EGR, should I or should I not?. It did throw a check engine light.
3. I was thinking about going with the edge juice, is this good? and what are my options. I noticed people talking about SCT and being able to turn off the egr etc... can I do this with the edge programmer. I am not looking to make a monster truck. Would just like to get the truck power up a little maybe around 100HP, but most importantly get it running efficiently
Sorry about the long post and all the questions, but I figured I would ask my question's here, I find when i start looking for answers to one question you end up reading for hours and don't get to the other questions
Old 11-08-2009, 08:06 AM
smokersteve smokersteve is offline
The eng is more efficient in its operation with lower boost because of the egr and exhaust upgrades
Old 11-08-2009, 08:44 AM
OK that's good news, thanks for the info.
I had another question as well, I forgot to ask earlier. I engaged my 4x4 two days ago and the light came on but no 4x4, I went to turn of the 4x4 and the light would not go out I had to turn off the truck inorder to get it out. Now I cannot even get the light on. I checked the vacume it's good, I have power to the back of the switch but there is no power going down to the transfer case motor when I check it. As well is there only one fuse for this system, the only one I could find and it's OK is the one on the D/S in the engine compartment fuse panel.
Old 11-08-2009, 08:57 AM
RJM06590 RJM06590 is offline
Built Not Bought
As everyone will tell you stay away from edge it will hurt your truck get the sct with custome tnes from innovative or any of the other guys
Old 11-08-2009, 09:38 AM
Thanks this is the stuff I need to know, how about bully dog?
Old 11-08-2009, 09:40 AM
Built Not Bought
na same thing sct is the very best and safest when using custom tunes, they tune everything in the trans and engine as not to damage it
Old 11-08-2009, 02:22 PM
This is verygood to know, thank you very much
Old 11-09-2009, 01:52 PM
bump......
