Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > General 6.0L Discussion
Old 11-07-2009, 09:19 AM
HeavyAssault HeavyAssault is offline
Question Oil temps cooler than coolant temps
Okay anyone got some insight in temps. How can I be running cooler oil than my coolant? I'll double check the temps but oil temps reading 155* when coolant is 185*-190*.
Any ideas?
Old 11-07-2009, 09:55 AM
Dan"gerous" Dan"gerous" is offline
If you are still running the EGR cooler your exhaust is heating the coolant.....
Old 11-07-2009, 10:12 AM
Modded EGR up-pipe so the exhaust is bypassing the OEM EGR cooler. Good thinking though.
Old 11-07-2009, 11:31 AM
bismic bismic is offline
Water pump problems perhaps.
Old 11-07-2009, 12:05 PM
alwil alwil is offline
Mine was doing the same thing......the more I drove the cooler my oil got, my coolant stayed normal.
I replaced the eot sensor and it solved the problem....for like 35$.
Old 11-07-2009, 06:48 PM
I think I'm using the wrong PID with the scan gauge.
Old 11-07-2009, 07:06 PM
Abrannan19 Abrannan19 is offline
I would think water pump possibly aswell. Grab that bottom radiator hose and it should be hot, if not, thats a good sign of a water pump failure.
Old 11-08-2009, 04:36 AM
roadrunner roadrunner is offline
if you are reading eot with your scangauge could you let me know the code to do so?
Old 11-08-2009, 06:32 AM
It's an AreoForce gauge, not the Scan Gauge.
Old 11-08-2009, 06:36 AM
Dave Dave is offline
Obama sucks
Same gauge. Aero force is the maker of the scangauge :
