- HOME
- FORUMS
- GARAGE
- ARTICLES
- CHAT
- CLASSIFIEDS
- VIDEOS
- TECH
- STORE
oil change frequency
after reading quite a bit here this is what i am going to do regarding oil type and changing frequency;
rotella t 5w40 synthetic year round that will be changed every 10k motorcraft filter that will be changed every 5k thoughts? |
| Sponsored Links |
Same as HeavyAssault...only use Mobil1 5w-40, change primary oil filter with only Motorcraft at 7500 miles. I also use Amsoil's EaBp 100 >2 micron bypas filter and change it every other oil change or at 15,000 miles. I do dump the EaBp filter and thouroughly clean the top and refill it with oil as well before adding new oil to the system. I also use the Fumoto drain valve which helps (less mess) and a have a silver dollar sized magnet near the drain plug (since I no longer have the old drain plug magnet) |
Without a oil bypass kit I still couldnt see going 5000 miles in between oil changes. The guy before me changed his oil every 5 thousand miles and ran normal 15w40 and man you should see my injectors. They are all gummed up and burnt oil on them. After seeing that I couldnt even run synthetic oil 5000 miles without changing oil.
I researched OA's, oil reports till my head was ready to melt. I discovered the majority of users running bypass kits were only getting 10K (maybe better) out of the oil. So why tempt fate? I use the OEM interval of 7500 miles but I don't exceed 10k between changes. Sometimes work or other requirements will cause me to go above the 7500 so I try to stay under 10k at that time.
These motors aren't picky they just need clean fluids. I spent the money to get this motor and damn sure going to take care of it as best my knowledge and the knowledge we share will allow. |
| Sponsored Links |
