Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > General 6.0L Discussion
  #11 (permalink)
Old 11-07-2009, 05:30 AM
diablos30 diablos30 is offline
so you would recommend changing oil and filter every 7500. its not like it would be that much more of an expense i just thought synthetic would last that long.
perhaps i'll so both at 7500, like you say we paid good money for the motor and dont want to f it up.
  #12 (permalink)
Old 11-07-2009, 06:08 AM
topdwg topdwg is offline
Originally Posted by MoyockPowerstroke View Post
Same as HeavyAssault...only use Mobil1 5w-40, change primary oil filter with only Motorcraft at 7500 miles. I also use Amsoil's EaBp 100 >2 micron bypas filter and change it every other oil change or at 15,000 miles. I do dump the EaBp filter and thouroughly clean the top and refill it with oil as well before adding new oil to the system. I also use the Fumoto drain valve which helps (less mess) and a have a silver dollar sized magnet near the drain plug (since I no longer have the old drain plug magnet).
I'm running pretty much the same as you. Here's where I differ though. I'm running Valvoline 5w40 synthetic and at 5K I'm doing an oil analysis. At 10K I do another analysis and if it come back good I'll only change the full flow filter. I'll go to 15K and here I'll change everything no matter what and that includes both full flow filter, Amsoil EaBp filter, and oil. I'm running the Fumoto valve and magnet on both my oil and tranny pan too.
  #13 (permalink)
Old 11-07-2009, 06:23 AM
elm302 elm302 is offline
how often does everybody change the fuel filters
  #14 (permalink)
Old 11-07-2009, 06:31 AM
Every 12 to 15K for me...
  #15 (permalink)
also amsoil has a full flow filter that replaces the oem filter and according to tamsiol you can go just as long on that filter as you can on the bypass filter idk tho
  #16 (permalink)
Old 11-07-2009, 07:09 AM
Hmm, well I went to there site and all I could find was this one and it didn't say anything about going as far as the bypass filter
AMSOIL SDF88 Oil Filter
For Ford 6.0/6.4L Power Stroke Diesel Pickups. Features cellulose media designed for OEM-recommended change intervals. Compatible with BMK11 and BMK21 bypass systems. Replaces Donaldson P550528 and WIX 57312.
  #17 (permalink)
Old 11-07-2009, 08:36 AM
smokersteve smokersteve is offline
well for standart oil I dont go past 6k. With syn, after a few oil changes to get all the standard out of the system so that you have full syn in the eng, you can go to like 7-9k. but going that much farther it would be best to get a bypass filter.
  #18 (permalink)
Old 11-07-2009, 08:55 AM
i talked to one of my buddys hes a dealer for amsoil ill try to get the part number he said it was like 30.00 bucks and it would be good for like 20k or so it was made out of some fancy stuff lol
  #19 (permalink)
Old 11-07-2009, 09:04 AM
HeavyAssault HeavyAssault is offline
I go by the OEM interval for fuel filters even using the AD 100 setup.
As with the oil changes I just did enough reading to make up my mind on the interval.
As far as brand goes I read enough to conclude that there was not ONE particular oil that really stood out as the best oil to run in the 6.0L motor. They all shear down to 30wt in like 3k miles from what I recall. Schaffer's was better at resisting the shear of the 6.0L. I chose to do my own research and found what works best for my motor. It runs great with Mobil 1 or Valvoline Extreme, it works okay with Rot-T syn and Schaffer's, and HATES cold weather with Amzoil. Not one brand or weight improved my MPGs to a reasonable measure over the life of the 7500 miles. I was able to tell what makes the motor run better by sound and performance. Of course I have NO proof other than my personal senses. When you drive 100 miles a day you tend to notice a lot about the way the truck responds and sounds that it makes when driving.
  #20 (permalink)
Old 11-07-2009, 09:08 AM
Do some reading on the Amzoil site. I tried that filter with their oil without much improvement. IIRC, The 20k claim comes when using only their oil and filter together. I had to ask myself what is so special that I can't use another oil with that filter? It shouldn't matter at all don't you think?
