Stupid Question, Sorry
As the title says this is a stupid question, so here goes. When checking the oil do you go all the way down, i.e. bottom out the cap OR do you only go until the bottom of the cap touches the tube? Reason I ask I was browsing around on the org last night and I read where someone said to do this? They said this is what their owners manual said to do? I've been checking oil on vehicles for a long as I can remember and I've always went all the way down, but considering this is my first diesel I figured I might ask.
Thanks |
I can't beleive someone hasn't commented on this. No one else is curious?
i go all the way down till the tube bottoms out. the only reason i can think of that someone might not, is that the 6.0 is happiest when the oil level is in the middle of the lines on the dipstick. so only taking the dipstick down till the yellow handle hits the tube is giving them the reading they want???
![]() but anyway, i take mine to the bottom and only fill it to the middle of the lines. |
Yea that's what I do. I was just curious since I read where someone hadn't and they referenced it from their manual?
Anyone else???
Let me go look in my owners manual. BRB
"Because it is normal to add some oil between oil changes, check your engine oil level each time you stop for fuel. To check the engine oil level consistently and accurately, the following procedure is recommended:
1. Have engine at normal operating temperature (at least in to NORMAL range on the engine collant temperature guage). 2. Park the vehicle on a level surace, then turn off the engine and open the hood. 3. Allow at least 20 minutes after engine shut down to assure that the oil contained in the upper parts fo the engine has returned to the oil pan. 4. Protecting yourself from engine heat, pull out the dipstick, wipe it clean and reinsert fully. 5. read oil level on both sides of dipstick and use hightest level (reading) for the actual engine oil level. 6. Maintain the oil level between ADD and OPERATING RANGE on the dipstick by adding oil as required. The distance from ADD to OPERATING RANGE on the dipstick represents 1.9L (2 quarts). Do not overfill. If the oil level exceeds OPERATING RANGE, oil consumption may result." With being said "reinsert fully" I would insert the dipstick untill it stops in the tube. |
Yea who is gonna sit at a fuel station 20 minutes to wait to check their oil??? haha
I say "No, it's not." I tell them I check my oil in the driveway at my house in the morning after it's sat all night. The oil level is fine. You'd think because they work at an oil change place they would know that.....
girl brings jeep to jiffy lube for a oil and filter change girl leaves and on her way home she calls me and says, my oil light is on and i just had them change my oil...did they forget to reset something? and BTW its making a funny ticking noise. well it turns out that they guys there forgot to put oil back in. this is way i do all my own work or have the ford service dept do it back on point..i set the dip stick all the way down |
