Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > General 6.0L Discussion
  #21 (permalink)
Old 11-06-2009, 12:25 PM
Snake Snake is offline
Originally Posted by Dave View Post
No it cant be done with supertech. But can be with ATF. However its not recommended.
jm812003 two stroke is a much better choice for what you suggested. ATF is not a true lubricant. The ratio is roughly 1 oz per gallon. 1 quart per 29 gallon tank is close enough
+1
--Snake
  #22 (permalink)
Old 11-06-2009, 12:26 PM
Originally Posted by ianstew View Post
i run crisco and snot in mine, and i get 49 miles to the gallon and it purrs like a kitten.
If I wanted to, I could run Crisco in mine.
--Snake
  #23 (permalink)
Old 11-06-2009, 12:27 PM
Originally Posted by redsmoke View Post
what it is funny is that guy that had that post a couple days ago where his mechanic buddy told him to talk his air filter off his truck so it would run better and he did it. I don't care who you are thats funny.
I remember that post -- THAT was funny!
To answer the follow on question, there is no gain. Only more risk.
--Snake
  #24 (permalink)
Old 11-06-2009, 01:20 PM
hypersnyper694788 hypersnyper694788 is offline
I understand 2 stroke oil because its meant to be burned with fuel in a 2 stroke engine. But ATF ?? not sure i understand??
  #25 (permalink)
Old 11-06-2009, 01:23 PM
Some people have access to free, used ATF. Since a diesel will burn it, they like to use it to cut fuel costs. Really bad for the environment and not so great for your injectors.
--Snake
  #26 (permalink)
Old 11-06-2009, 01:27 PM
Speedyboy487 Speedyboy487 is online now
Berm Buster
There was an article in DP of a guy running strait atf in a X I think. Had a decent amount of miles on it too. I would never do it though.
  #27 (permalink)
Old 11-06-2009, 01:35 PM
Ozone-etr1 Ozone-etr1 is offline
jumpin jiggawatts
my bicycle runs off of low amino acid H2O and i through a can of C4H4KNO4S (red bull) every now and agin
  #28 (permalink)
Old 11-06-2009, 01:39 PM
jumpin jiggawatts
Originally Posted by Mike Hickman View Post
How can plain old oil fire up and burn with out any diesel in it
So lets say I go out and say buy 4 gallons of atf dump it in and I'll be ok > Can this be done with super Tech as well ??
well when you shove it into a cylender at about 1200 deg f. with 25lbs of boost and you smash the sh!t outa it with 18>1 compression anything burns
  #29 (permalink)
Old 11-06-2009, 02:08 PM
rmikemcd rmikemcd is offline
Lol.
Friend of mine used to run used ATF, used motor oil and used parts washer fluid in his izuzu pup.
He got all of it for free from the shop he worked at.
Ran like a champ. Hell of a bad smell though.
  #30 (permalink)
Old 11-06-2009, 02:20 PM
BIGBILL105 45 BIGBILL105 45 is offline
My buddy has been running around every other tank of used ATF in his 99 7.3
