Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > General 6.0L Discussion
Old 11-04-2009, 09:40 PM
Ride Everything Ride Everything is offline
Tow ratings for 2003 don't make sense!
Hi all- I noticed the tow rating for a 6.0 TD 2003 F250 Crew Cab 4X4 single rear wheel is only 10,500lbs. The same vehicle from 2000-2002 and from 2004 to 2006 is 12,500 lbs. What happened in 2003? If you click the link below and look for this model, you'll then see a footnote at the bottom of the section noting this particular model is only 10,500 lbs. Anyone know why?
Thanks
http://www.trailerlife.com/images/do...owingguide.pdf
Old 11-05-2009, 06:20 AM
elibenson elibenson is offline
I wouldn't worry about it too much. With my 2003 6.0l F350, I towed a combined weight of 41,000 lbs on a really regular basis. It was a dually, but essentially it is the same axles, bearings, springs, etc as yours.
