HID HELP!! - Ford Powerstroke Diesel Forum
Old 11-04-2009, 02:45 PM
HID HELP!!
i just got a 10k hid kit from wholesalexeonhid.com and everything looks good besides the fact there is no plug conector to go into the truck wiring. i hold the truck headlight wire in my hand and there is 3 wires, black, blue w/ white tracer, and green or something, i forget. the hid kit had a red wire and black wire that is soposed to got into the truck harness? if this is correct what 2 wires do i tap into out of the trucks 3. if this makes any sense to you, please help me out. THANKS!!!!
Old 11-04-2009, 02:58 PM
I just ordered this kit, and I heard installation was cake. Aren't there plugs at the end of your kit?
Old 11-04-2009, 03:00 PM
h13..........
Old 11-04-2009, 03:04 PM
Send a message via AIM to dirtrider1253
i had the same problem when i did this. i used a test light to find out which wire was for the low beam in the trucks harness and then also the ground. then i tapped the black wire into the ground and the red wire into the low beam wire
Old 11-04-2009, 03:06 PM
so i guess say good bye to high beam??? also do you remember what colr the low beam was?? im thinking the blue w/white
Old 11-04-2009, 03:09 PM
no no no lol you have 3 plug in wires right? you have to plug them into the stock plug there should be 3 holes in the stock plug that the 3 wires plug into
Old 11-04-2009, 03:13 PM
i have 2 wires from the hid kit to go into the 3 wires in the trucks light harness. and there is no plugs in the hid kit, just 2 wires a red and black
Old 11-04-2009, 03:32 PM
ok well mine was a 99 so its a little different but i got the kit for a 05+ its had 3 wires from the kit that plugged into the old stock harness yours looks like an 05 so idk if the harness is the same if it has 3 plugs in it plug the 2 wires in it one in each then turn the high beams on then turn the lights on and see if they work...if the kids a low beam xenon/high beam halogen leave it on high otherwise theres a chance the xenon bulb could blow it happened to me with mine
Old 11-04-2009, 03:33 PM
the hids i have are the ones without the high beams so they only had two wires with no plug on them and i just tapped them into the trucks headlight wires and havnt had a problem since
